Old 08-07-2009, 01:54 PM
AndyJCP AndyJCP is offline
Default Pre-Amp / AD for my SPDIF inputs on Digi003
Hi DUCers,
I'm thinking of using the SPDIF inputs on my 003 for recording voice in a small studio.
Can you recommend any combination of pre-amp and AD converter? Or something combined in one unit?
I'm looking for something that I can use to color the tone a little, like a tube preamp.
As far as price is concerned: It matters!
So, I am not thinking about something from Avalon or Neve or Apogee. I was more looking for SPL Goldmike or Presonus TubePre with a RME ADI2 or something similar.
Any recommendations?
Thanks a lot, as always!
Andy
Old 08-07-2009, 02:13 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Pre-Amp / AD for my SPDIF inputs on Digi003
I have a Dbx386 dual vacuum tube .
http://www.dbxpro.com/386/386.php
- Jesus Alvarado -
Keep the volume UP !
Old 08-07-2009, 02:18 PM
soundmaster soundmaster is offline
Hi Andy,
ever thought of that one ?
J.
PT HD 9.0.6/Win 7 pro SP1 64bit/Q6600/EMU1820m
PT 9.0.6/HP 8560w/ProFire2626+Octane
Old 08-07-2009, 02:27 PM
rqstudio rqstudio is offline
Joemeek TwinQ has 2 channels, EQ, and Compression, Shop around, you can get them new for around $700 w/o the mic package.
Old 08-07-2009, 02:29 PM
albee1952 albee1952 is online now
Presonus Eureka on a budget
API A2D for "no holds barred"
Old 08-07-2009, 02:36 PM
TCM's Avatar
TCM TCM is offline
Originally Posted by soundmaster View Post
Hi Andy,
J.
The Envoice MK II is a good channel strip and easy to handle and possibly in your price range.
The Eureka is also very good.
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 08-07-2009, 07:28 PM
scar97 scar97 is offline
I use the presonus eureka with the optional card. If you get 2 of them you get 2 more channels
"It aint about the stuff you got..If it sounds right you're finished..Burn it!"
For all complaints click here
DAW
Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent
Old 08-08-2009, 01:21 AM
Thanks a lot! I've looked at all three (dbx, eureka, envoice).
Do I understand correctly that I need the additional AD card for the eureka while dbx and envoice ("digital edition") have built-in AD converters?
I'm a little in favor for the mindprint, simply because it has a lower price.
One general (maybe a little dumb) question:
Why do I need an EQ and compressor on the input side of the DAW? Isn't there the risk to "over-commit" to something I cannot correct later?
Old 08-08-2009, 01:32 AM
TCM's Avatar
TCM TCM is offline
Do I understand correctly that I need the additional AD card for the eureka while dbx and envoice have built-in AD converters?
The card is optional for the Eureka. For the Envoice as well (I have got one without). But there were some good deals for the Mindprint lately that included the card.
A channel strip just gives you more options to adjust the signal coming in. Just don't overdo especially compression.If you use an outboard compressor and slam the signal, it is very difficult to correct ITB.
Are Digi003 line inputs TRS? Mike Borok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-18-2012 05:14 PM
digi003: hum on inputs 1-4 ? HELP !!!! jaunmanuek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-10-2009 01:38 PM
PT8 on a DIGI003 Rack: Why am I only getting 2 inputs present on the input tab. sharpo07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-28-2009 02:09 PM
Monitor Mode inputs 3-4 on the Digi003 Rack 29th of July 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-26-2009 04:12 PM
Digi003 Mic inputs 1 thru 4 allegrarc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-13-2008 07:29 PM
