#31
Re: Emulate Timeline Cache benefits on your Mac for FREE!
#32
Thanks, Dism!
#33
Stumbled on this which can create a file system link that redirects to a ramdrive...which purports to sync back to the original location. May be a longshot, but might be worth checking out.
UPDATE: It installs in mandarin but has English mode, but only does the "sync" when you unmount the Ramdisk, so it's not really quite as automated as I thought. It is interested how it can create a file-path that is redirected to a Ramdisk though. PT10 could always be "thinking" it's launching a session from my Tracking drive, but it's really opening/running from a ramdisk. I'll play with it, but I'm not sure this tool will be a fit... http://www.macupdate.com/app/mac/265...sk-utility-pro
iMac i7 & MBP Retina i7 OSX.9.2 /Pro Tools 11.1.2 (w/ special guest-star appearances by Logic 10.0.6) / RME FF800 + Dangerous D-Box "I survived the Great Launch Predicaments of PT11 2013." |
#34
Successfully created Ram disk, but after copying the session to the Ram disk got the alert "This session is saved on a volume set to “Transfer” only."
Tried to change settings in Workspace but got "'ramdisk' cannot be designated as an Audio Record volume because it is not a fixed, removable or MediaNet volume." |
#35
When you log on to a local network, you initially get the same message. The network drive will be set to T (transfer only). But in this case you just change it to P (playback) or R (record) and from there on it will work. Wonder if there's a similarity here where the RAM disk is seen as a network drive. I've been meaning to try to log on to an ftp with a speedy upload and try to create a session directly on the ftp and record one track to it ... just for fun to see if it would work Anyone else tried that with PT 10 ? Chris
Chris Lambrechts Applications Specialist- Live Sound |
#36
Oops, I should have said I was trying this with PT 9 - tee hee
#37
Go to Disk Utility and reformat the disk as Mac OS Extended (Journaled). Lemme know if it works!
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
#38
I've been running it all morning. Solid so far!
On the RAM Disk I consolidated 24 edited audio tracks during playback... took maybe two seconds. Opened the same session on the HD and consolidated the audio tracks during playback. Yep, it took longer, and halfway through the process got the classic "DAE can't get audio from the drives fast enough" error. I see now that some have been doing this for a while on the PC side. Not sure how I missed it on the LE forum. Glad I got it now. |
#39
Great tip though, Dan! Thanks. Quote:
I tried that too but it won't let you change the ramdisk to Record or Play. When doing so PT pops up the same error message. |
#40
HD Native disc and timeline cache? | David Sandwisch | Pro Tools HDX & HD Native Systems (Mac) | 2 | 09-29-2013 08:45 AM |
Timeline Cache in Windows ..HOW ? | jeam25 | Windows | 0 | 12-10-2012 10:25 AM |
Timeline Cache in Pro Tools 10 for FREE! | corp | Pro Tools 10 | 1 | 11-11-2011 07:31 PM |
PT10 + CPTK = Timeline Cache? | bootc | Pro Tools 10 | 11 | 10-24-2011 12:22 AM |
Difficult sound to emulate | MixMastaShizNasta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-06-2004 08:23 AM |
