Old 03-17-2011, 11:08 AM
batchmister1 batchmister1 is offline
Default Help! 410,610, & Fast TRack Ultra Issue
I had a brand new Firewire 410 that worked fine. Then one day I stopped being able to record my keyboards using the analog inputs.
I bought a Delta 1010 and I could record through the analog ins but I sold it becuase I didn't like it.
I replaced the firewire PCI card and got a brand new Profire 610. I had the same problem with it. So I returned it and got a Fast Track Ultra only to find out that I have the same problem. What's should I do?
Pro Tools software version: Pro Tools 8.04 M-Powered
CPU: Intel Pentium 4
Processor spped: 2.31 GHZ
OS version: Win XP SP 3
Ram: 2.93 gb
Hard drives: Internal 700gb
Old 03-17-2011, 11:27 AM
Cal D Cal D is offline
Default Re: Help! 410,610, & Fast TRack Ultra Issue
If the same problem occurs with all those cards, make sure that the actualkeyboard and cables attached to it, are not defective.
Also, Fast Track Ultra comes with a software mixer facility. Click on the icon and make sure that mixer is on screen where you can see it. There is a tab called Meters. Switch to that, play your keyboard and see if it moves any meters. if it does not, it could be that on the Fast Track Ultra mixer, you don't have the sliders up for your input channel(s). Check that. Also check that your software return sliders are returning a signal.
fast track ultra issue with sonar x2 perera64 Tips & Tricks 1 09-11-2013 04:37 PM
Fast Track Ultra 8R pro tools ten issue toxiccity Windows 1 02-25-2013 10:24 AM
New PT10 User. MBox3, MAudio Fast Track Ultra, MAudio Fast Track 8R? epu Pro Tools 10 3 06-13-2012 03:55 PM
track confusion in fast track ultra interface deck Pro Tools M-Powered (Win) 0 02-24-2010 10:17 AM
