Crossfade default length
How can I choose the Crossfade default length?
Re: Crossfade default length
The crossfade length is remembered from the last entered value.
In other words, if you use the crossfade dialog to make a 5ms fade, the next time you call up the crossfade dialog, it will already be at 5ms. |
It's also found in Setup -> Preferences -> Editing tab.
Prefs/Editing/Default Fades.
If all the regions on a track is side by side after grid and I select all the regions and hit crossfade (command + f), would the size be what I choose in the preferences?
With Command Focus On, all you need to press is F. Otherwise, the Fade Dialog will open with your Default setup.
If you for some reason need to have Commands Focus off, you can hit Ctrl-Command-F to create fades, which won't open the dialog box.
Setting of 'Edit Window Default Length' | critictalk | Tips & Tricks | 1 | 07-30-2013 10:39 PM |
Default selection length | MFPBand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-30-2012 04:09 PM |
Edit window default length limit - why? | trc229 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 09-21-2009 06:59 PM |
Beat Detective: Can I change the Default crossfade? | dcrann11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-12-2007 04:39 AM |
change default fade length | swpowe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-29-2006 01:26 PM |
