Sharing mixes between Mbox and TDM System
I have recorded 7 songs with a digi 002 at 44K and 48K.
I have done the majority of my mixing with Mbox 2 and my Mac Mini. In order to utilize the array of mastering plugins on an OS9 TDM system I have available, I am exporting my mixes from the mini (track by track) into the TDM system. I have not adjusted the audio on any of the tracks yet the mix and audio of some tracks sound different (bass not as audible/levels not quite the same). I am assuming it is only because the TDm system is not running the big and bassy KRK monitors that I am running with my mini. Just checking to see if anyone has experience with sharing mixes beteen systems and if it's possible if audio can be compressed or altered while importing/exporting. Also, as an experiment, I am bouncing some of the tracks at higher quality than I recorded (recorded 44K or 48K and bouncing at higher 96K or other at "tweak Speed'"). Will I experience a difference or is this a waste of time and I should just bounce at the same rate. Any info would be appreciated. Thank you. |
Re: Sharing mixes between Mbox and TDM System
If you are making a sample-for-sample copy, the audio won't change. Listening to the same audio on different speakers will change the "sound" of the sound.
You will gain nothing at all by bouncing to a higher sampling rate. You will lose half of your computer resources, however. Stay at 44.1 unless you need 48k for video sound tracks.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Thank you.
I can't seem to find the sample-to-sample option. How do I confirm that this is how I am exporting? Thanks
Setting up speaker system to A/B mixes | Sonic Blue Meanie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-05-2011 09:59 AM |
Sharing my system securely? | delta | Pro Tools TDM Systems (Mac) | 9 | 05-09-2008 02:11 PM |
Sharing Songs in Between an Mbox 2 and a 002 | vsideproductions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-08-2006 08:22 PM |
Sharing sessions between H/W (Mbox, 001)?? | ChrisBreitner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-22-2003 06:55 PM |
plugins sharing PT6 and mix system | digigirly | Pro Tools TDM Systems (Mac) | 0 | 09-20-2003 07:13 AM |
