Old 05-14-2003, 08:10 PM
ThreeBlake ThreeBlake is offline
Default HD2, 02R96 & USB Extenders
Hi All,
I am looking at building a system that has the G4 mounted in a machine room with the 02R96 (as a control surface) in the control room.
I will be running the dual VGA monitors & USB down a Gefen extender (150' cable run) and am not sure if I will encounter any problems with the 02R96.
Is anyone out there is this type of config?
I look forward to reading your replies,
Duke.
Old 05-15-2003, 05:02 AM
nmiller79 nmiller79 is offline
Default Re: HD2, 02R96 & USB Extenders
will you be running usb...if so do not even get me started..
NM
Old 05-15-2003, 05:26 PM
Yeah, I will be using the USB to talk to the 02R96 as a control surface for the Mac/HD2 system.
Duke
DVI extenders. Marsdy General Discussion 5 09-19-2011 07:16 AM
How to Hook up MCU and 2 Extenders? ReverbMerv ProControl, Control|24, Command|8 2 12-23-2006 10:45 PM
firewire extenders Craig F Tips & Tricks 1 05-04-2006 07:30 PM
Mackie MCU and Two Extenders? ShakaBrah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-10-2005 12:32 PM
kvm extenders Gef Pro Tools TDM Systems (Mac) 9 02-24-2001 02:33 AM
