PT 10 and "all" interfaces
Hello all.
Brand new to the forum....... In looking to upgrade to PT 10, my major concern is compatability. Is it true that PT 10 can be used with all types of audio interfaces, e.g. anything MOTU, edirol, and others.... or is it still proprietary: digi002, 003, mbox, M-audio(M-powered), etc... I also read that you need Windows 7, Windows vista will not work? Thanks in advance Chris |
Re: PT 10 and "all" interfaces
yes, you can use just about any interface now http://www.pro-tools-expert.com/pro-...dware-checker/
I'm using OSX but I do believe that it is correct that you need W7 over Vista
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Yes pretty much any interface will work with PT 10, I am using a third party interface. You do need Windows 7 for it to run efficiently also.
yep pt10 with rme ufx here = rock solid
Cheers ! |
Thanks alot fellas.... really helped....
Chris |
Yes, you need Windows 7(Vista stinks anyway, so trust me...you won't miss it)
Just to clarify, Protools 10 will work with any ASIO compliant interface. There are sone older interfaces that do not comply to this standard or do not have an ASIO driver. It should also be noted that the original Mbox, Digi001 will not work (as stated by Avid). Some folks have also had issues getting those USB mics (designed for podcasts) to work but some do work.
Protools 10 for Windows will work in Windows 7 but not Windows Vista. A stated above, Vista was a crappy OS and you wouldn't want to use it for your DAW anyways. Most people pretty much jumped from Windows XP to Windows 7.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.4 running Protools 2024.3 Mac Studio M1Max - 64GB MacOS 14.3.1 running Protools 2024.3 |
"Low Latency Monitoring" with 3rd Party Interfaces | RokVox | Pro Tools 11 | 10 | 03-02-2016 12:52 AM |
Can I use any of these "guitar" audio interfaces with PT10 HD and Asio4all? | Georgerob | Pro Tools 10 | 11 | 01-29-2014 02:16 PM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
