Old 12-18-2004, 12:12 AM
Illah Illah is offline
Default Can a Digi-001 system be used as a sound card?
This is a simple question (yes I'm a noob). I'm thinking of getting a Digi001 system and I'm wondering if it can replace my soundcard. In other words, if I were to play back MP3's with Winamp could I use the Digi001 as the output to my monitors? Or will it only be 'active' while ProTools is running?
Thanks!
--Illah
Old 12-18-2004, 04:35 AM
Bastiaan Bastiaan is offline
Default Re: Can a Digi-001 system be used as a sound card?
You can use the 001 as a soundcard if you install the wave-driver. That way you can play back everything, but you cannot record through it. In addition, there is a pretty good ASIO-driver for the 001. It can all co-exist together.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 12-18-2004, 05:41 AM
billsonbob billsonbob is offline
I;ve had the same question regarding my MBox. What is this driver and where do I find it. THanks!
<font color="#00FF00"> Crenshaw ... it's not just a melon anymore.
Old 12-18-2004, 07:51 AM
on top of this page you'll find a link called "downloads". I bet you can find there what you are looking for. The thing you are looking for is called "wavedriver" and "ASIO-driver". Be sure toi download the one for your OS and your Digidesign interface...
What's that?
Bastiaan
Old 12-18-2004, 07:53 AM
http://www.digidesign.com/download/wave/ thats the link.
also you may want to look into Rails little program vcalled MME-helper to assign more proigrams to be able to use the digidesign interface as an output.
What's that?
Bastiaan
Old 12-18-2004, 10:19 AM
So will the wave driver enable output from games as well? I don't need full 5.1 or anything, just 2 channel output is fine for something like Half Life 2.
--Illah
Old 12-18-2004, 11:17 AM
KingFish KingFish is offline
The wave driver is still "hit and miss' with some apps, I doubt if you'll be able to use the driver to play all your Game Audio through your digi hardware, some may work, but most probably will not.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Old 12-18-2004, 11:44 AM
rokko rokko is offline
hi
i'm currently using the 001 with several other apps in Windows XP without problems. The Wave Driver is pretty poor but works with Sound Forge and others for playback at least. ASIO drivers are pretty good. I'm using WaveLab5 and Nuendo2 with them and actually work.
Regards
Rocco.
Old 12-18-2004, 12:18 PM
Third Eye Studios Third Eye Studios is offline
I would suggest if you still want to be sure to hear all your games and other stuff to leave in the stock soundcard. Take the output from the cpu soundcard into the 001 ins 3 and 4 when they are not in use for recording (1/8” stereo to l-r ts adapter from Radio Shack not included). Inputs 3 and 4 can be switched into the output signal path by the “monitor mode” switch on the front panel of the 001. Quick, easy, and guaranteed to work with every program.
Old 12-18-2004, 01:53 PM
phentalmyst phentalmyst is offline
whats the best way to do this with the 002 rack?
thanks!
`pm
Digi 001 As Sound Card Sharif 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-29-2007 03:16 PM
Advice on Digi card with another sound card... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-11-2003 06:00 AM
Do I need a sound card or Protools system?? Newbie questions Yee General Discussion 0 07-08-2003 10:18 AM
can i get the DIGI 001 SOUND CARD????? JINGLES STUDIO COLOMBIA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-23-2002 02:34 PM
Sound card with Digi 001 card? 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-08-2001 08:26 AM
