  #31
Old 02-01-2023, 08:09 AM
daeron80 daeron80 is offline
Default Re: The Aux I/O device has disappeared from the system and will be disabled
Originally Posted by its2loud View Post
If you change the name of the Aux IO, Pro Tools will automatically match your "To Zoom" Bus to the "To Zoom" Aux IO Output path also named "To Zoom". This is how changing the name will help you with this issue.
Thanks, I'll give that a shot. Thing is, I work on a wide variety of projects that require different setups. Studio, remote, and livestreaming. Sometimes, I'm hooked to my Clarett+, sometimes to an Apogee Duet, sometimes to an A&H SQ5. There's no way I can have a single I/O setup. Saving and recalling I/O setups doesn't seem to solve the problem.
David J. Finnamore
PT 2022.9 Ultimate | Clarett+ 8Pre | macOS 13.1 on a MacBook Pro M1 Max
PT 2022.5 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
  #32
Old 02-02-2023, 02:14 AM
chrisVVS chrisVVS is offline
Make a template that works for you and use Import Session Data to bring any other session into your working template each time.
  #33
Old 03-27-2023, 04:55 AM
tomguest.tv tomguest.tv is offline
2023.3 has made this issue worse for me - have tried all different buffer sizes..
Avid CoreAudio Device in System Preferences Daryl Hughes macOS 4 01-01-2014 10:41 AM
Mbox 3 not sticking as system output device darwiniandude macOS 1 12-15-2010 01:27 PM
I disabled Mbox in device manager - How do I enable again? stev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-27-2008 02:32 PM
master clock device for mix system? digidesigner Pro Tools TDM Systems (Mac) 2 01-30-2008 01:53 AM
Digi001 as preferential in\out multimedia system device? salvo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-02-2000 01:40 AM
