Old 01-24-2009, 12:28 PM
Seitz333 Seitz333 is offline
Default Click Track Problem - Default Sounds Missing
I'm using an Mbox 2 Pro Factory and I just finished installing everything and all the upgrades to PT8, I think...
When I create a new session and use a click track the only sound I hear is what I'm guessing is a MIDI impulse. It does not matter what sound I select Cowbell, Marimba, etc... the only sound is of the MIDI impulse.
Did I forget to install the sound files? Are they pointing to the wrong folder?
Thanks,
Chuck
Old 01-24-2009, 08:38 PM
pianosound pianosound is offline
Default Re: Click Track Problem - Default Sounds Missing
Maybe you've allready tried this, but if not hope this helps. If you hit control 1 (1 on the number pad I think),,, you will bring up the transport window. Look down to the lower right,, you will see a little guy, looks like a director. Activate,(click on him), and you should then hear your click sounds. Again, if you are an long time PT user, you probably allready know this, and I appoligize for wasting your time! But hopefully it is this simple, and you can get back to work!!???
Good luck either way,,, Mike
Old 01-25-2009, 12:26 AM
No,,,, wait ...,, wrong!!! not the little guy,,, but the 'METRANOME',,,, I hope I've gotten back to you before you read this!!! I hate giving mis information, and again I hope this helps and appoligize if it doesn't!!
Mike
Old 01-25-2009, 09:07 AM
Hey Mike, thanks but yes the metronome is activated.
Chuck
Old 01-27-2009, 07:49 AM
Still having the same problem with the Digi Click track. So for now I'm using the TL Metro plugin for a click track.
Chuck
Old 02-11-2009, 07:35 PM
FYI, I uninstalled everything and did a fresh install of PTLE V8 and it works fine now. Maybe it was a problem because I originally installed PTLE 7.4 then upgraded to PTLE V8?
Chuck
click track sounds LongRoad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-19-2009 02:24 PM
missing click track AND panning? bookerfatz2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-20-2008 05:35 AM
Missing Click track sound bookerfatz2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-20-2008 02:37 AM
Replacing Click Track sounds bakedbeansrecord Tips & Tricks 8 03-24-2007 02:28 PM
click track sounds fredsparky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-08-2004 07:33 PM
