Hello...
I am trying to record a line level analog audio signal on inputs 5-8 in Pro Tools using a Scarlett 18i8 interface. I'm able to record inputs 1-4 without a problem but when I select inputs 5-8 in PT First there is no signal. Focusrite control has no problem with these inputs but Pro Tools is not recognizing them. The inputs show up in the input list and are selectable but no signal is shown if a line level signal is being fed to the 18i8. Any suggestions? Thank you, William Scarlett 3rd gen with updated firmware Focusrite Control 3.7.4.1943 Audio Midi v.3.5 Pro Tools First 2021.6.0 |
2 things come to mind:
1-open the Focusrite "mixer" software and make sure that 5-8 are enabled, routed and turned up. 2-your signature shows Pro Tools First, so this might be a limitation of the software, especially if you are trying to do more than 4 inputs at a time(I believe PTF only allows for 4 "live" inputs at a time). If you are only trying to record on 5-8(without 1-4), then I'm confused too.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
That is true. It will only access the first 4 inputs from the interface. The only way to get higher than the 1-4 is to have in interface driver that allows you to re-arrange the order of the inputs putting 5-8 in the 1-4 position. I don't know if Focusrite Control lets you do that but you can definitely do it in the Red range.
James Cadwallader Mac Studio, 64GB RAM, 1 TB SSD, Glyph 2TB USB3 HDD, OWC drive dock, Mac OS Monterey 12.6.2 Pro Tools Ultimate 2022.12, HD Native, Focusrite Red 8Pre Presonus Faderport, Pro Tools | Control |
![]() Quote:
Red Range in combination with Pro Tools First sounds like an interesting decision… ![]()
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
![]() Quote:
HAHAHA! Sent from my iPhone using Tapatalk |
Red rage with Pro Tools First is more likely.
![]() ![]() ![]() ![]() ![]() Back to Pro Tools First(which is now discontinued), its a teaser designed to get folks a way to try it before they buy it. Its okay for recording podcasts and audio books, but if you want to record music, you really need a full-featured DAW. Most of us use PT because we like how it functions and/or, we need to be compatible with other PT users. Having said that, there are many options, including some that are cheap(Reaper at $60) or free(Cakewalk by BandLab, formerly known as SONAR). Any DAW should work great with the 18i8 and even the cheap/free options are very capable programs.
Unable to set inputs on the I/O section | LeoVilla | macOS | 2 | 02-17-2018 11:09 PM |
Unable to install new PT version, and issues with inputs, etc. in edit window | museman | Pro Tools 10 | 16 | 03-28-2015 08:10 AM |
Mbox2 Pro - unable to hear inputs without having PT on | cosmo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-25-2012 06:05 AM |
Unable to use Virtual Instrument Inputs and Outputs | dbonney | Virtual Instruments | 1 | 05-23-2011 10:50 AM |
Unable to view (or select) all 4 Inputs in Pro Tools I/O | halljr1 | Pro Tools M-Powered (Mac) | 1 | 11-27-2007 07:34 PM |
