Old 06-07-2011, 02:20 PM
el biciclista el biciclista is offline
Default How do I connect monitors with Eleven Rack and Pro Tools?
I am a Pro Tools HD guy, so please forgive the dumb question.
My son is going to buy:
(1) An Eleven Rack, which comes bundled with Pro Tools LE 8, to record guitar tracks.
(2) A MIDI keyboard to control Pro Tools and create MIDI tracks for use with virtual instruments. This will connect to the Eleven Rack MIDI In.
He will use a MacBook Pro laptop.
He may stay with Pro Tools LE 8, or upgrade to Pro Tools 9 (hopefully the latter).
Question:
(1) How does he connect monitors to this system?
Can these be connected directly from the laptop outputs, or does he need a hardware interface?
(2) Will there be a latency problem when he monitors the mix while recording a guitar track? He would connect the Eleven Rack to the MacBook Pro via USB.
Old 06-07-2011, 07:57 PM
Default Re: How do I connect monitors with Eleven Rack and Pro Tools?
OK, I found the Eleven Rack Users Guide and I see the monitors are connected to the Eleven Rack. So, the Eleven Rack acts as the I/O box for Pro Tools.
However, the only connection shown between the Eleven Rack and the computer is the USB connection. this is fine for integrating the Eleven Rack into Pro Tools, but how does the audio data flow between the two? If you are recording into Pro Tools while at the same time monitoring the mix with monitors connected to the Eleven Rack, there have to be audio cables between the two.......lots of audio data will be flowing between the computer hard drives and the Eleven Rack.
What am I missing??? Duh.
Old 06-07-2011, 07:59 PM
The audio is traveling in both directions over the USB cable, just as it does with an Mbox.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
How to connect other hardware to Eleven Rack and make it work in Pro Tools 11 TENM Eleven Rack 0 03-11-2014 05:55 AM
How to connect the Eleven Rack and a Pod HD together webstersp Eleven Rack 5 01-04-2012 04:02 AM
Connect iPhone to Eleven Rack Pluck Eleven Rack 7 10-13-2011 08:10 PM
Eleven Rack Won't Connect bloodbath666 Eleven Rack 1 03-24-2011 05:03 AM
Eleven Rack won't connect spandol Eleven Rack 2 02-02-2011 08:32 PM
