Video Problem with Mix+ , Help?
i have a project where i have problems with the video-playback.
System PT TDM 6.41 , OSX .39 , Video : DV Pal 24 fps, Miro DC 30 card Quickpunch enabled , preroll 3 sec. The Behavior in play mode is fine and snappy. When we try to record , the Video-playback is in the first 2 seconds stuttering (2-3 fps) (in the preroll) and is after theese 2 seconds ok. So far i remember i saw this behavior only on HD systems but had theese problems not on my mix+ system. All otherSession i have are fine. I mainly use dv or mjpeg A codecs. I checked preferences and peripherals but found nothing wrong. Recording limit is set to 5 min. I tried save session copy in... no success. The session is coming from an PT8 system where it was saved as an 5.x/6.x session. Btw i tried first session data import to a new session but had always crashes , so i had to use the original session to work with.(but thats an other story) I assume there is anything corrupt with the original session, the audio or the video file. any help would be nice
foley artist , soundeditor |
Re: Video Problem with Mix+ , Help?
Is the video on a separate drive from the audio ?
That's always a good idea. .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
there are seperate OS- , audio- and video hd..
the problem occurs only on certain sessions , coming from PT 8 or above sessions, and only in the preroll if quickpunch is enabled, which is a pita when recording foleys..
video problem since 10.3.2 maybe? | crizdee | Pro Tools 10 | 3 | 11-09-2012 04:37 AM |
Problem with video in PT8 le | toronjaasesina | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-15-2010 05:11 PM |
PT 8 LE Video problem | 7777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-15-2009 03:15 PM |
Video Problem-Please Help | MichaelBross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-19-2007 03:31 PM |
BTV Pro Video Problem | lamxeditor | Pro Tools TDM Systems (Mac) | 6 | 08-29-2004 08:14 PM |
