Old 07-30-2002, 07:26 AM
tranqs tranqs is offline
Default Delay when press the "rec" button
I'm having problems to record any track in pro tools free. When i press the rec button starts a huge delay!!! anyone knows how to stop this?
Whem i press the mute button the delay disapear but i think this is not the solution.
thanks
Ps. I'm using a soundblaster PCI 128 with a pentium III 1,13 GHz and 384Mb of RAM bernardo@tjdf.gov.br
Old 07-30-2002, 08:49 AM
Default Re: Delay when press the "rec" button
In the truth I am having problems with the signal of audio. When i press the button "rec" seems that the audio is duplicated causing a delay in the sound that i heard
Old 07-30-2002, 04:19 PM
Stone Knife Stone Knife is offline
Open up your transport to full view (Display> Transport window shows> MIDI Controls)
Check to see if the "2 Bars" button is lit. If so, click it so it dims.
You may have a 2-bar countoff before the transport engages. This same problem drove me nuts for awhile.
The delay you may be hearing could be a function of DAE latency. You can choose a smaller buffer size to shorten the effect, but the best bet is to mute the channel you're recording to, while listening to the other tracks you've already recorded.
HTML code is On
EuCon command for old Command8 "Plug In" window button? myhrik Pro Tools TDM Systems (Mac) 6 06-21-2013 03:48 AM
Cannot quantize audio - "Apply" button doesn't work jlnelson19 macOS 2 02-19-2013 01:59 PM
MBox "launch control panel" button not working again with the latest driver Zarabozo Windows 0 10-26-2012 12:01 AM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 06:45 AM
Why is my "Midi Merge" button grey? I don't have the option to press it. Violet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-19-2009 05:57 PM
