PT 2021.3.1 not seeing the HD Native Thunderbolt
Newly upgraded to 2021.3.1 from P.T. 11.3.2.
PT 2021.3.1 is not seeing the HD Native Thunderbolt (It's not available as an option in the Playback Engine dropdown menu). Digitest shows the HD Native Thunderbolt The system works fine with P.T. 11.3.2... Yes I have the Digi Link I/O authorization on my iLok… Any guidance would be appreciated... Studio-PC Processor Intel(R) CoGB (31.9 re(TM) i7-6700K CPU @ 4.00GHz 4.00 GHz Installed RAM 32.0 GB usable) System type 64-bit operating system, x64-based processor Edition Windows 10 Pro Version 21H1 |
Re: PT 2021.3.1 not seeing the HD Native Thunderbolt
Did you clean install or install over ? Try quitting PT,, then holding down the (N) Key while launching PT ( this usually works on Mac ) If that doesn't work try trashing PT preferences,,, then again hold N key and launch
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
Did you install the latest HD drivers included in the installation folder for 2021.3.1?
Hi Kev and its2loud,
Yes, clean install, The option for HD Native Thunderbolt does not show up as an option in the playback Engine dialogue no matter how I access it (from the setup menu or holding down the N key upon startup) The Win HD drivers are installed with the P.T. 2021.3.1 main program install. |
Try this
Trash Pro Tools Preferences for Windows Pro Tools 11, 12, and 2018 Close Pro Tools. Hold the Windows key on your keyboard and press R. When the Run window appears, type %appdata% and press OK. Open the Avid folder, and delete the Pro Tools folder. Restart your computer and launch Pro Tools.
small world as I recently ran into the same issue.
PT 2021.3.1 does not support HDx , HDNative, Omni and other Avid HW: https://www.avid.com/pro-tools/comparison Only supports Carbon You will need to "upgrade" to ulitmate. This was my last straw with Avid and PT as it makes zero sense to release SW that does not even support your HW. |
Hi Dan,
Thanks so much, you nailed it (the hard way). I had asked my sales person directly if ProTools worked with Sync HD and if I needed the Digilink I/O licence to work with my Merging hardware before purchasing both... They said yes, It actually works with neither. Wow. Thanks again, Regards, Neal |
Thunderbolt via HD Native box vs. Strictly Thunderbolt | TheGrobinson | Pro Tools HDX & HD Native Systems (Mac) | 3 | 09-29-2022 04:30 AM |
Hd Native with ProTools 2020 & 2021 | lagol | Pro Tools 2020 | 6 | 04-17-2021 09:58 AM |
Avid HD Native Thunderbolt and Thunderbolt Cables. | SoundEng1 | Buy & Sell | 0 | 10-30-2018 10:24 PM |
HD native thunderbolt with thunderbolt card on desktop PC? | martthie_08 | Pro Tools HDX & HD Native Systems (Win) | 9 | 10-12-2016 10:26 PM |
HD native thunderbolt through Echo Express SE Thunderbolt Chassis | hkj1 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 11-06-2013 05:49 PM |
