11.2.2 Stability
Hows it working for anyone? Any major show stoppers? Pretty solid on 11.2.1 here.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
Re: 11.2.2 Stability
As with any and all updates, have a backup plan!!!! Mine is to save a drive image first, or I clone the current system drive(and I then swap the fresh clone for the original system drive). If the update turns bad, I swap the old drive back in and go back to work
fine so far on 10.10.1. Just installed an SSD as a main system drive, installed PT11.2.2 on it fresh, and works like a charm.
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
I've had one crash on 11.2.2 which was right after installing Toontrack Superior Drummer. But it only happened once and has since been behaving itself so I don't know what caused it.
I had no problems on 11.2.1 though and have a backup so will go back if absolutely necessary.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Ive had 3 crashes in 11.2.2
woking in melodyne simply working in the arrange,net page editing some audio and another one I can't remember thats about 3 more than 11.2.1 around the same time there were a few other plug ins with updates that I did. so who's to say where the fault lies but still is pretty wierd. I have a clone to go back to, if it gets too troublesome. With everything going on lately - the new licensing stuff. seems pretty lame.
Jay-J System MacPro 12 Core 24 G Ram 10.12.6 PT 12.8.1 Mbox 3 Pro Plug-ins Verified 4 HD OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
11.2.2 not good. Can't deal with not being able to switch inputs and outputs, and not being able to switch MIDI CC views in the MIDI edit window.
Switched back to 11.2.1 and all is well again.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
I'm currently coning back to 11.2.1.
Wow this company is really sinking isn't it.
I just got a similar crash like I was getting in 11.2.2. editing some audio zoomed in and zooming in and out a bit while playing back. feels just about the same crash.
This one is after cloning back to 11.2.1 which was pretty stable. BUT when i went back to 11.2.1 I re updated my plug ins that were recently updated. Compressor Bank 5.3.20 Filter Bank 5.3.20 MC2000 5.3.20 Multiply 1.1.1 Sonnox Codec Toolbox 1.0.4 these Sonnox were v 1.4.1120 Dyn Inflator Limiter EQ Reverb Supressor Trans Mod Ultra Channel 2.0.19 So I assume its one of these causing PT 11.2.2 to crash, since 11.2.1 was very good for me. Before I start rolling back again to 11.2.1 and NOT doing these plug in updates above. Is there any link you see to those ALSO having crashes in 11.2.2 I personally feel its this type of information we need to share and be specific about around here to help us ALL Achieve Stability. Anyone see a link to their own crashes, based on my system specs (currently shows 11.2.2 but i went back this morning to 11.2.1)
Sorry if this seems redundant. Just wanting to understand exactly what you are talking about.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Yes. Click on the output button of any track. Say it's set to A1 and you want to switch it to A2. You select A2 but nothing changes, it sticks at A1. The workaround is to switch the output to NONE first, then you can finally switch to A2.
Same thing for inputs. And MIDI CC data doesn't switch types either. And there's no workaround I can find because if I want to switch from viewing Mod Wheel data to Expression in the MIDI editor window, there's no "NONE" to select in-between. All is well in 11.2.1 thankfully. I switched back.
PT 8.03 stability woes | Mothlight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-20-2010 01:03 PM |
6.7 vs 6.9 stability | brianjanthony | Pro Tools TDM Systems (Mac) | 7 | 09-13-2005 02:05 AM |
G5 stability? | 1m1 | Pro Tools TDM Systems (Mac) | 3 | 01-07-2004 08:03 AM |
Stability | nny | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-16-2001 01:12 PM |
G4 500 with PT 5.0.1 Stability? | cander | Pro Tools TDM Systems (Mac) | 5 | 10-01-2000 06:55 PM |
