M1 macs
M1Pro with 32 gigs of ram or M1max with 16 gigs of ram? Mixing and Mastering only
Sent from my iPhone using Tapatalk Last edited by mark7; 04-29-2022 at 04:32 PM. |
Re: M1 macs
Large sessions? Lots of VIs? Video? Loads of samples? More info and I'm shure you'll get some sound advice.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Re: M1 macs
16 gig of RAM I'd consider a minimum for a Pro Tools machine.
You want this to last several years as software gets more bloated.. then definitely get 32 (or 64GB). You have no option to upgrade memory in future. |
Re: M1 macs
For me, 16 on my M1 is plenty. w/PT I mostly mix smallish sessions with few Vis, no video, and I never see swapped memory, Activity Monitor always in the green. I also use Adobe Lightroom Classic with quite a large library, and it uses half of the 16 at most. If I run a semi-busy session in PT while having Lightroom catalogue open, I might get into the orange in ActMon memory, but I don't see any effect on performance. (I'll be running internet browser and small apps also.)
Re: M1 macs
I had 32GB on my i7 2018 Mini thru the last year and a half, and I never saw ActMon get into anything but the lower greens. Using a few GBs of disk cache in PT, I always felt like it was a waste. If you have more memory than you need, it's a waste of money, I always thought. 128GB of ram doesn't mean a thing if you don't use it.
Of, course, Darryl is right to point out that the M1s' memory is not upgradable so you'll have to consider that. But the question on pro32 vs max16 is a question of what is most important to you and your purchase; memory requirements vs CPU/GPU requirements.
PT 10 & 11 on two macs | chris.d | Pro Tools 11 | 2 | 07-28-2013 10:07 AM |
intel macs vs. slightly older macs | Jperkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-14-2007 09:36 AM |
Using 2 Macs | raindog | Post - Surround - Video | 6 | 05-31-2007 12:51 AM |
New Macs | Greene | Pro Tools TDM Systems (Mac) | 6 | 12-21-2002 10:09 PM |
New Macs | hmurchison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-13-2002 12:24 AM |
