Installing 10.2 update - reinstall???
I got and installed Pro Tools 10 (PC) a few days ago.
Although pretty well versed with audio software in general, I have not had Pro Tools before, so this is probably a newbie misunderstanding... I found there was an update (10.2) available, and downloaded the files accordingly. Upon running the 10.2 setup, there was a message box indicating that setup had found a previous version of Pro Tools, and that I had to uninstall it prior to continuing the 10.2 setup. I think I must have made a wrong turn somewhere because I have installed a LOT of updates to a lot of software and have never had to completely uninstall the current program in order to apply patches or program updates. Can someone tell me if this is really the way one updates Pro Tools? Many thanks - |
Re: Installing 10.2 update - reinstall???
If it says to uninstall, uninstall.
It's not a big deal... Just open the uninstaller, and do a clean uninstall. Takes maybe a minute, and your plugins aren't touched. Then, install 10.2. Easy.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
2 things make it a big deal. 1-you must uninstall the HD driver too, and 2, you should save a drive image before this, or ANY update or software installation.
BTW, I could be wrong on this, but it seems that updates that are designated x.x.X don't require uninstall-reinstall, while updates that are x.X do. It really depends on what fixes are included.
After I had troubles the first time I installed PT8 (over 7.4.2), this has become my modus operendi for installation. Finally... if 10.0.0 is still working fine for you, is there really any particular reason to upgrade to 10.2? Always stop and think before making any major updates. Unless there is a particular feature or bug fix you need, updating can be more trouble than it's worth. If it works, don't fix it!
OK, thanks - I appreciate the reponses.
So I believe my take-away from this is: "Yes, that's normal and what you have to do." So it was written, so shall it be! I shall proceed accordingly, stopping short of tossing out my soapbox! All the best, -S |
Hi everyone....
I recently purchased Pro Tools 9 that came with a FREE upgrade to Pro Tools 10. I kept running into problems and it was recommended by a ProMedia person AND in my Pro Tools handbook that I do a "clean uninstall/ reinstall". I am on an Imac with 10.6 Snow OS x. I did the re-install and only got Pro-Tools 9 re-installed. I know I don't know everything and am a relative newbie. I am usually very good at dealing with software, but I have never had an I-lok before and never dealt with upgrades sent via e-mail, etc. I really thought there would be some sort of warning or explanation if I needed to do something special to reinstall the Protolls 10 upgrade. I am so frustrated....please help. I hope I am just not understanding something simple. Thanks... |
PT reinstall + update | R3dlight | Eleven Rack | 4 | 11-08-2012 03:53 AM |
Update to 10.3.2 failed, can't reinstall 10.0 | rickluque12 | Pro Tools 10 | 5 | 11-01-2012 10:33 AM |
UPDATE to 10.3.1 , do I need to reinstall AVID VIRTUAL INSTUMENTS | phatbeatstudio | Pro Tools HDX & HD Native Systems (Mac) | 5 | 10-08-2012 04:14 PM |
After installing Crossgrade, how would I reinstall from scratch? | Doug Ring | Pro Tools 9 | 2 | 12-20-2010 10:53 AM |
help with reinstall/6.4 -6.9 update | DjA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-12-2005 12:39 AM |
