Old 05-27-2008, 07:32 PM
jallen jallen is offline
Default Midi notes keep playing
I'm not sure exactly where to post this problem, so I'll start here.
I have Pro Tools 7.4 LE on a Windows XP Laptop. I also have a M-Audio Axiom 61 Keyboard Controller, connected up via USB to the laptop, and I have an older Korg-SG-1 Keyboard with the midi-out going into the midi-in of the Axiom 61.
I'm running the XPand virtual software, and several times now.. when playing a key, that note just stays on forever, and there's no way to stop it, like its an infinite loop or something. The only way to stop the note from playing is to shut the keyboard off altogether, but then I lose all midi capability, and then I need to reboot the laptop to get everything back again.
I've seen this happen with the XPand virtual software, and with the B4 organ plugin. Its happened right in the middle of a session, which isn't good.
Any ideas how to prevent this from happening??
Old 05-27-2008, 08:30 PM
Default Re: Midi notes keep playing
Shouldn't that be MIDI Thru if available? If not, un-plug the SG-1 and try again.
filosofem
Aaron Mulqueen - 001 HD Native
Old 05-28-2008, 05:49 AM
shea shea is offline
Go to event and all midi notes off or hit control+shift+.
seamus
Old 05-28-2008, 06:30 AM
Thanks for the replies, very much appreciated.
Unfortunately, the M-Audio Axiom 61 doesn't have a Midi-Thru option, it only has Midi In or Midi Out.. I should have picked up on that before.
Maybe I'll have to purchase one of those multi-port Midi Interface boxes.. unless someone has a better idea???
Old 05-28-2008, 07:34 AM
Im not sur of what your trying to do but you should not need midi through it compicates things.
Why are you using two keyboards and what audio card are you using?
seamus
Old 05-28-2008, 08:30 PM
I play two MIDI Controllers (keyboards) simultaneous all the time, though I do have a multi-port MIDI Interface, no daisy-chain.
filosofem
midi notes not playing back properly guitarhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-20-2013 11:40 PM
Playing Reason with recorded midi notes jamescampagnola Pro Tools 10 1 11-26-2012 12:35 PM
Pro Tools not playing all midi notes Jepse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-16-2010 01:23 AM
Midi chaos (playing notes on its own) Ryan Young MIDI 11 05-13-2009 12:20 PM
MIDI records two notes when playing one 2A Batterie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-13-2004 08:22 PM
