Rewire with reason problem
Ok, I need to know how to fix a issue. I have use rewire to connect reason but when I hit play to record the reason stereo track into protools. The song is at the default tempo of 120 in protools. How do I make sure the tempo is always at the tempo of the reason song I load.
Thanx |
Re: Rewire with reason problem
Reason, or any rewire application for that matter, will follow the master application's tempo (in this case, the master app is Pro Tools). You would need to set the Pro Tools tempo to match the tempo of your Reason session.
Yes like spkguitar say...will follow the master application tempo...and also you can change the beat...in Reason you can't change your key signature (in the same song)but with PT, reason will follow the key signature and tempo...
For example: The verse is in 4/4 at 120 then you change for the chorus to 6/8 at 100...cool no? Peace Thierry |
Reason/Rewire problem in PT9 | rgfeaster | Pro Tools 10 | 3 | 12-30-2011 07:31 PM |
Reason 4 problem with ReWire | bdane | macOS | 0 | 10-14-2011 01:13 PM |
Reason 3.0 Rewire Problem | tommy2fingers | Virtual Instruments | 1 | 02-08-2007 09:39 AM |
Problem with Reason, Rewire, and PT7.1 | StarSonicEnt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-26-2006 08:52 AM |
Problem with Reason Rewire | Glenn75 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-18-2004 09:06 PM |
