MTC Question
Hi people I am new to the Mac platform and I have recently loaded in Protools 6.0 for the 001.The Mac is a new G4 1.25 running OSX.My problem is that DIGI dosen't seem to be generating MTC or MIDI Beat clock.I have enabled MTC to port within the 001 software,also have gone in AMS>Midi Set Up,Assigned MTC transmits/recieves,assigned channels,assigned clock,assigned MMC.The 001 is connected to an AMT8 Midi interface via Midi cable,the AMT host is a windows sequencer and have had no problems wit the old PC SET UP.In the Midi set up/menu within the MAC it reports the 'device is online' ,I can't figure what might be wrong and thought maybe some one can help.Thanks and Cherers.
Re: MTC Question
I am having the same sort of promblem with syncing to an akai mpc2000, worked fine in pt5 but wont do it in pt6.
Someone please help.
2018 Mac Mini 3.2GHz 6-core, 32gig ram - OSX 13.4 - Protools Ultimate 2023.6.0 - HDX PCIE in Sonnet Thunderbolt 3 box - Apogee Symphony Mk1 |
Re: MTC Question
Make sure that the Frame Rate Settings match (Drop, Non Drop, etc..).
Unlike earlier PT versions, in 6, if you forget to match that setting with your other gear, PT just sits there and "waits for sync". In the "old days", PT would just happily go along regardless of this setting, whether it was right or wrong and you had to "remember" to check it. dk
www.dpksound.com |
Re: MTC Question
Thanks people I am going to try to reinstall pro tools,I have mathched the frame rates within the software and still not even the midi beat clock is seen on the AMT8.I will let you know bzldzl if I have any relevant result.Cheers.
Re: MTC Question
I am still doing something wrong with syncing an akai sampler to pt MMC. I did the frame rate in session startup.
Any other help? Thanks
Re: MTC Question
Akai mpc2000xl says waiting for time code
Re: MTC Question
HI everyone,bzldzl sorrry I can't offer a lot of help but this is I can suggest,try the upgrade to 6.01.I can now generate Midi time code[DIGI MIDI PORT OUT TO AMT LOGIC INTERFACE]but is still very unstable,the MTC message allways stops within 10 minutes where as Pro tool 5 use to generate for hours[having to relaunch protools to start MTC each time].Can anyone help could this be a ram issue?I am running only 256 meg on a new G4 and am very unimpressed by this slack performance with such a simple task.CHEERS.
Re: MTC Question
How about some help digi cs
Re: MTC Question
Yes, I too am having this same problem..... I lock up my MPC to the 001 via PT6.0 (G4 1.4ghz)and it stays locked for a minute or two(if I'm lucky) then I have to restart the program to get a new lock. DIGIDESIGN WHAT IS GOING ON. Where is the update for that!!!!!!
Re: MTC Question
same problem still, digi cs has me now on a two day call back so they can try to figure out what is wrong
i stop at about 40seconds syncing to an mpc200xl Please fix this very soon digi
fruity loops in pro tools question...not regular rewire question | nutrinoland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-23-2010 12:39 PM |
quick question - Mbox Mini question - i forget | JRup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-18-2009 02:55 PM |
Another optical expansion question question for boffins | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-23-2008 11:21 PM |
General Venue Automation Question - (Maybe dumb question) | TwoPort | VENUE Live Sound Systems | 5 | 12-21-2007 02:41 PM |
Chipset Question/Hard Drive Question | andrewkstone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-26-2006 08:15 AM |
