Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2021
Old 11-17-2021, 11:32 AM
Stephen Bond's Avatar
Default Re: Ultra Wide Monitors Woes Woes With Mac mini M1?
Just got the new super spec 8K cable, Back on the LG ultra wide and one minute in with Pro Tools and the screen went blank again
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Big Sur, Pro Tools 2021.10, Focusrite Scarlett 2i2
Save an additional 10% off any purchase at Waves!
https://www.waves.com/r/9zsnwd
Old 11-17-2021, 11:35 AM
Have you tried SwitchResX as per my post above?
Old 11-17-2021, 12:00 PM
eightamrock eightamrock is offline
Stephen
What refresh rate are you set at?
Old 11-17-2021, 12:13 PM
Id also just ensure that gamemode and freesync are both off. Freesync should be off by default if its not supported, but just check it anyway.
Old 11-17-2021, 01:08 PM
No. I missed that nugget. Thanks for pointing it out. I'll try that next!
Stephen
Old 11-17-2021, 01:10 PM
Apple M1:
Chipset Model: Apple M1
Type: GPU
Bus: Built-In
Total Number of Cores: 8
Vendor: Apple (0x106b)
Metal Family: Supported, Metal GPUFamily Apple 7
Displays:
LG ULTRAWIDE:
Resolution: 2560x1080 (UW-UXGA - Ultra Wide - Ultra Extended Graphics Array)
UI Looks like: 2560 x 1080 @ 75.00Hz
Main Display: Yes
Mirror: Off
Online: Yes
Rotation: Supported
Automatically Adjust Brightness: Yes
Was at 75Hz. Just switched to 60Hz. Will report back!
Stephen
Old 11-17-2021, 02:48 PM
The other thing which might be symptomatic of the issue is the sound just disappears when listening via HDMI via the speakers. Watching a YouTube video via the screen is all good until the sound dies at random.
I can get it back by disconnecting the HDMI cable or turning the monitor off and on. I'm left with the new sound option and the old dead one, see pic.
Stephen
Old 11-17-2021, 02:53 PM
capt kirk capt kirk is offline
you may have a broken/intermittent connector IN THE MAC.......its possible
www.kfaudio.ca
Old 11-22-2021, 06:32 AM
A couple of replies on a FB group mention trying a ThunderBolt to DisplayPort cable as that should fix the issue. So I'll go shopping again and report back.
Stephen
Old 11-22-2021, 06:56 AM
MarkH MarkH is offline
Before I purchased an Apple XDR I used to use Dell U-Series 38" Screen LED-Lit Monitor (U3818DW), Black on my 2019 Mac Pro using the Dell's USB-C port instead of HDMI or Display Port and everything worked fine. It's like it was meant for Mac. All positive reviews by Mac owners on Amazon.
BTW, when you click System Preferences > Display, to see ALL supported resolutions hold down Option while clicking Scaled. You don't need a third party app for this anymore.
Mini Grand Woes eheilner Virtual Instruments 4 08-13-2021 11:06 AM
Ultra wide monitors ZEUSS Pro Tools 11 2 12-27-2014 12:35 PM
Regular Ultra wide -Ultra 3-enclosures the same? elementsound Storage Subsystems 0 07-03-2004 02:43 AM
001 w/B&W G3 Ultra Wide espmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2000 07:40 PM
ULTRA WIDE 3 LVD jjblair General Discussion 3 02-10-2000 10:37 AM
