Pro Tools and DA-88 synch, how??
I have to make dubs/stem mixes of a mix I did (back-up for TV) on Pro Tools onto DA-88.
I have the SY-88 Synch card installed on my DA-88 and I have a 888/24 and a USD, and Pro Tools vers 5.0 (no jokes please, it's just for video [img]images/icons/rolleyes.gif[/img] ) I'm going analog out of my 888/24 into the DA-88 (can't afford the $500.00 Tascam AES/EBU-TDIF box). What would be the best way to synch, Pro Tools as slave, or DA-88 as slave? What I ended up doing was slaveing Pro Tools to SMPTE out of the DA-88 but at first I was trying to have the DA-88 slaved to Pro Tools. Couldn't make that work, so I went the other way, Pro Tools slaved to DA-88 via SMPTE. Can I generate timecode from my Pro Tools Session and send it to my DA-88 for slaving? What methods work and how do you make the connections i.e. AES/EBU, Word clock, MTC, SMPTE, this gets a little confusing to me and I have to go back and forth between three manuals, and none of them have an exact answer or setup for what I am trying to do. Thanks. [img]images/icons/smile.gif[/img] [img]images/icons/confused.gif[/img]
Karen Basset Boom Chic Studios Los Angeles, CA 90048 [email protected] http://www.boomchic.com |
Re: Pro Tools and DA-88 synch, how??
Take word clock out of the USD into your DA88 -- set the DA88 to clock off external word clock and set it to chase SMPTE that you generate from the USD/PT.
Rail
To make ProTools generate code using your USD, go into Session Setup (Command+5). Set USD to Generate.
Then put ProTools 'On-Line' (You must do this for code to actually be generated) Feed a WordClock signal from your USD to your DA-88. All should be cool. |
Thanks guys,
I'll give the word clock a try. [img]images/icons/smile.gif[/img] What other options do I have for synching the DA-88 to Pro Tools? Thanks again.
How do I synch the Triton to Pro Tools Properly? | HB1978 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-08-2009 10:16 PM |
Getting Venue to Synch Midi From Pro Tools | TwoPort | VENUE Live Sound Systems | 4 | 11-13-2008 07:10 AM |
Audio in synch with quicktime, out of synch in FCP | WannabeSQ | Post - Surround - Video | 6 | 09-20-2006 06:47 AM |
synch Pro Tools LE with video from DV camera?? | doozerco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-21-2004 02:50 PM |
Pro Tools and DA-88 synch, how? | Boom Chic | Post - Surround - Video | 7 | 04-11-2002 12:32 AM |
