i started off with pro tools 12 on MacOS Mojave. I was making music with my friend who hooked up his maschine to my i mac. after making beats on FL Studio 20 we dragged the stems to Pro Tools 12.
After we saved and closed the session i reopened it it crashed and gave me this message - "The application pro tools has quit unexpectedly. The system and other applications have not been affected." - I get this message when I start up pro tools 12. I was successfiul at getting another session to open which clearly showed the beat stems was what was crashing the system. after several trials nothing could get pro tools 12 to open anymore. Moved the plugins into the unused plugins. Still no help. I went thru and checked every plugins, Upgraded from Mojave to Ventura. Ive trashed the preferences, upgraded to pro tools studio. Upgraded my MacOS to Ventura 13.0.i Still stumped. |
Your description isn’t very clear at all. Are you trying to get Pro Tools 12 to run on Ventura???
You also have provided no information about your exact hardware setup. We need very specific details to be able to help. |
![]() Quote:
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Hi, welcome to the community.
You must refer to 2022.12, right? PT12 is ancient already. Compatibility info here.
My apologies and thank you for the steadfast replies. Im pretty new to this. I was using Pro Tools 12 on my 2015 I Mac with a Apollo twin X interface. After the crash came about I replaced pro tools 12 and purchased Pro Tools Studio and upgraded my macOS from Mojave to Ventura thinking that the upgrade would solve the problem. I was doing fine with what I had and felt no need to needing to upgrade. But I did with no luck.
How can I do that?
![]() Quote:
Macintosh HD/Library/Application Support/Avid/Audio/Plug-Ins/ to a temporary location. Trash your preferences Bring up Pro Tools, see if it gets off the ground. If yes then start moving your plug-ins back into; Macintosh HD/Library/Application Support/Avid/Audio/Plug-Ins/ Maybe 10 at a time. Bringing PT up after each addition. Let us know how it goes.
![]() Quote:
Already tried that. No luck. |
If you get a dumpfile when this happens highlight it, copy it to Textedit and save it as a pdf. (I mispoke, zip files are not valid here)
Then use attach files at the bottom to load it up here.
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? | ZerglingPhilosophy | Getting Started | 1 | 09-02-2022 03:43 PM |
"Pro Tools could not load the following plug-ins" on Native Instruments plug-ins | Joachimoj | Windows | 6 | 08-14-2015 04:42 AM |
Pro Tools Crashes during "Restoring Tracks" portion of startup | rhythmator | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 12-28-2014 10:42 AM |
Pro Tools Crashes on Startup During "Setting Up I/O Paths" | ChrisIQ | Pro Tools 10 | 3 | 08-24-2013 05:27 PM |
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 | danball | macOS | 2 | 09-26-2011 04:49 PM |
