Old 06-03-2020, 10:12 AM
EddieJones's Avatar
Default Re: s1 not cycling through automation modes to 'read'
No, its the Rec/Auto Switch Press changes......
Old 06-03-2020, 10:25 AM
JingleDjango JingleDjango is offline
Thanks. I'm relatively new to EuCon.
No change in behaviour with that setting applied.
Old 06-03-2020, 01:52 PM
EddieJones's Avatar
If you start a new blank session with just one mono track does it still do it? Theres got to be something specific about your setups or settings. We still can't reproduce here on multiple systems in multiple locations and I really want to get this into the 20.6 release.
Old 06-03-2020, 02:22 PM
Yes, same issue in a blank session with only a single mono track. Is there a tool I could run to give you some more diagnostic information? A netstat readout maybe?
Old 06-04-2020, 11:05 AM
EddieJones's Avatar
and if you change the mode in PT it shows OK on the Control App? Also can you change the modes OK On the Control Apps Mixer page?
  #16
Old 06-04-2020, 11:20 AM
I'll double-check tomorrow when I'm back at the studio. Or maybe someone else with the same issue can confirm.
  #17
Old 06-04-2020, 11:22 AM
swethington swethington is offline
Also tested with a blank session, single mono audio track but it didn't make a difference.
When changing the mode in PT the Control app changes along with it (I checked on the meters, channel and mixer pages).
Changing the mode from the Control app mixer page also works as expected. Same for the Channel page. By "as expected" I mean that changing it from the Control app causes PT to update the mode accordingly. It doesn't work from the meters page but I don't believe it's supposed to (I'm also new to the S1/Eucon workflow so I might be wrong about that).
You mentioned the Rec/Auto switch option, that was how I had it set originally when I came across the issue. I just tested it again and it doesn't seem to make a difference if this option is turned on or off, same behavior either way.
So from what I can tell it's only an issue when switching modes using the S1. The Control app and PT seem to be behaving as they should (to the best of my knowledge anyway).
Mac mini M1, 16 GB RAM, Ventura 13.3.1, Pro Tools 2023.3, Avid S1, UA Apollo Twin UAD-2 Satellite
  #18
Old 06-04-2020, 11:57 AM
EddieJones's Avatar
Can I confirm with everyone its getting stuck at Latch ?
  #19
Old 06-04-2020, 11:59 AM
Yeah, that's what happens for me.
  #20
Old 06-04-2020, 01:27 PM
EddieJones's Avatar
Can you all post an image of your Surfaces page from EuControl or give a description of what you have and in what order.
Global Automation Modes (and more...) PatrickCusack Avid S4/S6 1 04-10-2018 09:36 PM
System 5 MC Automation Modes Mike Hybrid System 5 6 07-10-2014 02:14 PM
Shortcut for cycling automation SZE Post - Surround - Video 3 09-24-2009 09:47 AM
change automation modes? Richard Fairbanks ProControl, Control|24, Command|8 2 07-11-2007 04:02 AM
bcf2000 & automation modes?HOW? maltezze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-29-2006 06:59 PM
