Unable to monitor spdif input on digi 001
howdy everyone. Here's my dilemma-
I buss 8 channels of A-dat optical into a yamaha 03d. The rest of the channels are bussed to stereo outs of the digi, which is analog 1/2 and spdif out. I can monitor everything fine on the yamaha board, and I send a stereo mix of everything from the 03d mixer back to the digi via spdif out of the yamaha. When I bounce to disk, the spdif signal sent from my mixer doesn't end up on the mix. I also cannot hear the returns (spdif) from the yamaha if I monitor from the digi 001 with my spdif cable going into the input on the digi. I think I'm missing a small but vital step. Any suggestions? |
Re: Unable to monitor spdif input on digi 001
Thanks Brent. I'll give that a try.
mix2much - do you have optical spdif output
source on your 02r that you can send spdfif signal to optical input on digi pci card? Have you gotten this to work? How? |
Yes, the optical works fine both in and out of the pci card. It was actually very easy. In the mix window, I chose the track I wanted to send to the board optically, and onthe output of that channel I had to change it from analog 1/2 to A-dat mono 1 (or whatever channel number you want it to be) I made sure my board was slaving to the spdif in clock of the digi 001.
Digi 002 - Can't Monitor Input | ragingcortez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-28-2011 07:44 AM |
where do I monitor optical input on the digi 002 or pro tools7.4.2 | dbluprecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-09-2010 10:41 PM |
SPDIF input Dropout on Digi 001? | fingerz88d | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-31-2005 11:09 PM |
switch auto input and input only monitor with midiprotocol | mmestudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-27-2003 03:51 PM |
No SPDIF input for DIGI 001 | flyin dread | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-19-2000 05:02 AM |
