Old 12-21-2014, 02:20 AM
SmokinBaldMonkey SmokinBaldMonkey is offline
Default PT 11.2.2 and higher will break Thunderbolt HDX functionality
If you are using Thunderbolt HDX on an Mac system running 10.10, the PTHD Software installers for 11.2.2 and 11.3.0 will break your thunderbolt connection and make the HDX card invisible to Pro Tools and OSX. The firmware updater does not work.
Though pro tools 11.2.1 worked great on Mavericks/Thunderbolt, Avid has removed it from the Avid account portal, you know, the one where we're supposed to have access to all our installers, past and present?
Veni, Vidi, Funki - I came, I saw, I laid the stank down
System 1: Retina MBP 512SSD/16RAM - Thunderbolt HDX1/HDIO
System 2: Mac Mini - 512SSD/8RAM - Thunderbolt HDX1/HDIO
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 12-21-2014, 02:51 AM
Default Re: PT 11.2.2 and higher will break Thunderbolt HDX functionality
That's right folks, regressing to version 11.1.2 (which isn't even certified for Mavericks) makes everything work like a well-oild machine again, while updating to 11.3.0 (which "has been certified on Mavericks") breaks the HDX Thunderbolt functionality such that Pro Tools can't even see the bloody HDX card at all. NO there is no bloody firmware update. It does not happen.
Thank you, Avid, for an entire day twatting around with these worthless installers and drivers. I SO much more enjoyed doing this than making music.
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 12-21-2014, 06:36 AM
Brandonx1 Brandonx1 is offline
Which chassis are you using? Firmware update works well for me in a pcie slot.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 12-21-2014, 02:02 PM
Sonnet Echo Express III. Which runs great and works with every other PCIe card inside it.
Upgrading to Pro Tools 11.2.2 or higher will cause the HDX cards to vanish. No firmware update, nothing.
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 12-21-2014, 02:58 PM
I would try to update the firmware in a pcie mac or pc andput it back on the chassis and see if it works. Also, I I don't think that chassis is supported but that doesn't mean it won't work. You might just have to jump through some hoops to make it work.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 12-21-2014, 08:40 PM
Bruce Paine's Avatar
Bruce Paine Bruce Paine is offline
Admin Emeritus
The 11.2.1 downloads have been added to your Avid account, with some of the other versions at the bottom.
Bruce Paine
System Details
Old 12-22-2014, 10:18 AM
Hugh-H Hugh-H is offline
Hello,
Thank you for posting your problem, we're in the process of updating several 10HD systems to 11HD, this is good to know if it's correct. Keeping an eye on your progress. The Sonnet chassis is qualified. I'm currently downloading v11.2.1 "just in case", we tend to keep copies of installers back a few versions due to issues like this.
Hugh
Old 12-22-2014, 02:04 PM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
Installed today a fresh Yosemite with ProTools HD 10.3, and it just works with my Sonnettech Echo Express III D... just one HDX card and one UAD octo card...
No problem there... BUT...
I just didnt get my 3 screens to work... what worked for a year with Maverick, will not work under Yosemite... 2 monitors 1080p and 1 TV 1080p HDMI.
Sometimes only 1 screen worked... reboot sometimes 2 but never all 3.
Tried everything... :-/
Luckly I made a carbon copy of my disk before I did the upgrade.
Im back on Maverick and everything is fine again... BUMMER.
But hdx was no problem with yosemite... protools just run fine.
Johnny
Johnny Hulst
Hulst Audio Engineering
MacPro (2019) 3,3ghz 12-core, 64gb Ram, 2Tb system SSD
Avid HDX, UAD-2 Octo, RME Hdspe AES & HD Native Thunderbolt
Sonnet M.2 4x4 PCIe (4x 250gb Samsung980pro)
Sonnet Allegro Pro USB-A 3.2, 4-port PCIe
Avid MTRX - mic/pre- & da-card, Dante Module,
MADI Module with SFP/LC module multimode 1300nm
MOM by DAD
192 I/O (64 analog inputs)
Avid Artist Mix
Genelec 1237A Sam
Genelec 1031A
Avantone mixcube
Rupert Neve RNHP
Old 12-23-2014, 08:10 PM
rinky rinky is offline
Confirming that HDX Thunderbolt (Magma) connection is broken after upgrading to Yosemite then PT 11.3.
Will have to go back to Mavericks and PT 11.2.1 as suggested.
Should have cloned prior to upgrades! What a waste of 2 days!
PT Ultimate 2021.3.1
PT HDX
MacPro 7,1
16 Core
96 GB ram
OS X Catalina 10.15.7
Somehow, musicians are now technicians!
Old 01-09-2015, 06:10 PM
Sonny Keyes Sonny Keyes is offline
Any developments on this? I just set up my new system, PT11.3 on HDX on a brand new Trash Can running 10.10 using a Magma chassis for the card and I've been scratching my head all afternoon trying to figure out why Pro Tools doesn't see the hardware. Do I really have to regress to 10.9 to make it work at all for the first time?
EDIT: Turns out it was a faulty Thunderbolt cable! Everything working properly now, running Pro Tools 11.3 on Yosemite on HDX with a Magma EB3T.
Sure is fast.
Sonny Keyes
Toronto
http://www.sonnykeyes.ca
Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20
Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10
HD native thunderbolt through Echo Express SE Thunderbolt Chassis hkj1 Pro Tools HDX & HD Native Systems (Mac) 1 11-06-2013 05:49 PM
Until Someone Makes a Thunderbolt Hub, Thunderbolt is a (1/2 Useless) Dead End Street relaxo Pro Tools 10 7 11-12-2012 11:43 AM
Thunderbolt-Sonnet’s Echo™ Express PCIe 2.0 Expansion Chassis with Thunderbolt™ Ports Barry Johns Pro Tools TDM Systems (Mac) 29 08-11-2012 07:01 AM
What is OMS functionality? pinkdaygreenfloyd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-10-2006 10:02 AM
002 functionality Bosskitty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-09-2006 12:57 PM
