Old 04-23-2009, 02:16 AM
pwrplay14 pwrplay14 is offline
Unhappy Please lmk if this computer is compatible
I need some help finding out if this computer is compatible for PTs 7.4 and sson to be PT8. I can't seem to find a list of chipsets to get and all the other things that are giving me a Wife induced headache. LOL Poor attepmt at humor but hey its 5 am. LMK if this will work or what I need to change. It is a custom build so I can change things if needed. Thanks so much to all the people on this board that help us newbies out.
Brian
I will be running XP Pro for the OS
System Configuration :
Intel CPU : Intel Core 2 Quad Q6600 2.4GHz, 1066FSB (Quad Core) 8000K
Intel CPU Fans : Spire Socket 775 Intel fan
Intel Motherboards : ASUS P5QL PRO P43, 1600FSB PCI Express, Sound, 1Gb
LAN
DDR2 memory : 4GB (2x2GB) PC5300 DDR2 667 Dual Channel
PCI-Express Video cards : ATI Radeon HD 3450 512MB PCI Express 16x dual head, tv out
Hard Drives : 80.0GB Hitachi/ IBM 7200rpm SATA2 UDMA 300 8m cache
Hard Drives : 250.0GB Hitachi/ IBM 7200rpm SATA2 UDMA 300 8m Cache
DVD Recorders : Samsung 20x DVD Recorder Dual Layer +R/RW -R/RW
Sound Cards : AC 97 3D Full Duplex sound card (onboard)
Network Cards : Ethernet network adapter (onboard)
Cases : PowMax Black Mid Tower ATX Case w/ Front USB
Power Supply : Okia 400W ATX Power Supply
Old 04-23-2009, 02:47 AM
mano111 mano111 is offline
Default Re: Please lmk if this computer is compatible
Read the first page of this thread first.
I'm still gonna comment on parts especially the ones that you need to consider changing
try to get something better. Arctic Cooling Freezer 7 pro or higher. otherwise keep the stock fan.
this ram is slow. get DDR2 1066 Ram or 800 if you cant afford it (this is very cheap anyway)
Drives are 8mb cache. very low for these days and Hitachi is IMO the worst brand name when it comes to HDs. I would change to Western digital and either 16 or 32 Mb cache.
Power supply and case are two of the most important elements in a build. These are practically "nonames".
If you care about this system's reliability and long life, choose a better case, and go for either Corsair, Enermax, or Seasonic Power Supplies. There are other PSU makers that are good too but you will need to do some research on your own.
400W is enough if the PSU is a modern 80+ model. I don't think the Okia is up to these standards.
About compatibility - most PT users with Qxxxx CPUs use P35 or P45 chipsets or higher. P43 will probably work but I dont recall anyone using it so its up to you...
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 04-23-2009, 07:19 AM
I agree with mano111 but would add this, when looking at power supplies, look for the largest fan as these tend to be less noisy(larger fan can turn slower). My Corsair supply has a 135mm fan and was $59 for 600 watts. The Hitachi drives are also my last choice.
Old 04-23-2009, 12:47 PM
Thanks for the help guys. Here is my reconfigured setup. If this is ok I will be done with this and it will be ordered. PLMK if this new system will work.
Brian
Intel CPU : Intel Core 2 Quad Q8300 2.5GHz, 1333FSB (Quad Core) 4000K
Intel CPU Fans : Cooler Master HyperTX Intel EXTRA QUIET Vertical HeatPipe Copper fan
Intel Motherboards : AsRock P45 TurboTwins , 2000FSB, DDR3 & DDR2, X-Fire, Sound, Gb LAN
DDR2 memory : 4GB (2x2GB) PC8500 DDR2 1066 Dual Channel
320.0GB Western Digital 7200RPM SATA2 UDMA 300 16m cache
Cases : Nikao Black Neon ATX Case w/side window & front USB
Power Supply : Antec Basiq 500w Extra Quiet ATX Power Supply w/ 6pin PCI-E
Old 04-23-2009, 02:31 PM
Much better though the switch to Q8300 is totally uncalled for. Q6600 has 8 MB of cache as opposed to 4mb on the Q8xxx. Larger cache is an advantage when it comes to PT preformance.
As for the motherboard again, try going with a 'proven to work' model. Check out the 'core 2' list I referenced in my previous post. There is no advatage in DDR3 support for these CPUs.
If you plan on using 003 or Mbox 2 Pro or an external FW hard drive you will need a supported FW card or a mobo with FW prot that is know to work with PT.
Old 04-23-2009, 07:24 PM
Hey Manno,
Thank you so much for the help. I have no idea what Motherboard to get. They list so many and when I try and match ones up with what other people have they are from over 3 years ago and are with 7.1 PTs and so on. Here is a link to the site where I am building this. Can you see what would be the best Motherboard to use.
Thanks,
Brian
http://cgi.ebay.com/ws/eBayISAPI.dll...09&refid=store
Old 04-23-2009, 07:41 PM
Look for this one
http://www.newegg.com/Product/Produc...82E16813131297
Old 04-23-2009, 08:51 PM
Hey Albee,
Unfortunately that puts me out of range costs wise. I am already well over my original 500.00 budget but I cant go that high for that motherboard. I just need something compatible.
Brian
Old 04-23-2009, 10:29 PM
TOM@METRO's Avatar
TOM@METRO TOM@METRO is online now
With most boards costing substantially less than the P5Q D, you will likely run into needing a separate firewire controller and still not having the stability this board can offer. But I understand about budget constraints.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2023 HDX Hybrid
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 04-23-2009, 11:38 PM
Would this be a suitable Motherboard with all the othe hardware I have.
Intel Core 2 Quad Q6700 2.66GHz, 1066FSB (Quad Core) 8000K
Intel CPU Fans : Cooler Master Intel Heavy Duty fan
Intel Motherboards : Gigabyte GA-EP43-DS3L P35, PCI Express, Sound, 1Gb LAN
DDR2 memory : 4GB (2x2GB) PC8500 DDR2 1066 Dual Channel (Check board compatibility)
Hard Drives : 320.0GB Western Digital 7200RPM SATA2 UDMA 300 16m cache
Is Pro Tools Compatible With My Computer? Majin General Discussion 0 12-19-2012 08:16 PM
Is this computer compatible with Pro Tools 7.4 & 8 flashmcclain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-18-2011 05:51 PM
new computer build, 001 compatible? zook250 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-30-2010 06:45 PM
computer compatible? BaileyBass Pro Tools TDM Systems (Mac) 2 05-26-2007 09:03 PM
is this computer compatible with m-box 2 pro?? gear head 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-31-2006 11:21 AM
