Headphones Cross-Feed with Dadman
I’m wondering if there is a way to setup cross-feed for headphones in Dadman’s monitor profile.
I would appreciate hearing if anyone had been able to set this up within Dadman without any additional plugins or apps. Thanks. |
Re: Headphones Cross-Feed with Dadman
Sorry I can't be more help, but long day. OK I saw this on the DUC from Jeff Komar. Maybe it will help. For reference -> this doc should help navigate the unit:https://www.dropbox.com/s/md2ktxtuy0...ource.pdf?dl=0 G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
I understand how to setup the Monitor Profile for headphone outs and cue mix, etc. I want to find out if it is possible to setup cross-feed to the HP outs and cue mix using Dadman. The following is how Grace describes their x-feed (cross-feed) feature in their m905 monitor controller: “X-feed (cross-feed) simulates the acoustics of a loudspeaker listening environment which can significantly improve imaging while reducing listening fatigue when using headphones. This feature employs carefully designed signal cross-feed, filtering and delay circuits to simulate hrtf (head related transfer functions).“ |
If you really want to do it, you would need to set up two monitors, apply SPQ delays/filters on the first monitoring path. Route that through a physical loopback back into DADman for the second monitoring path and then use a custom fold down matrix to sum the filtered/delayed signal from the opposite channel with the original signal for the actual ear. It would be MonitorA 2 out -> SPQ EQ/delay -> loopback -> MonitorB 2in from MonitorA + 2in original source -> fold down 4 channel to 2 channel -> Headphone out. Good luck with that. Lots of opportunity to get phase issues. Meanwhile the Grace m600 is $660 and has a simple crossfeed circuit
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 04-17-2023 at 04:54 PM. |
https://duc.avid.com/showthread.php?...reativecontrol
Don't feed the trolls | Ben Jenssen | General Discussion | 2 | 11-01-2022 09:15 AM |
Seperate Feed to headphones? | tandem | Pro Tools HDX & HD Native Systems (Win) | 1 | 06-27-2014 07:09 PM |
RSS Feed??? | i hear dead people | Pro Tools TDM Systems (Mac) | 0 | 06-22-2007 06:33 AM |
Feed Back | March314 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-20-2007 08:34 PM |
LFE feed level to Lt/Rt | CCash | Post - Surround - Video | 3 | 08-08-2003 08:10 PM |
