How can I insert a hardware effect into my master track?
I'd like to run my Master track through my BBE Sonic Maximizer (which is hardware, not a plug-in) so that the entire mix gets treated. I set it up with the BBE's ins coming from Digi001's 7 and 8 output and I have BBE's out's going to Digi001's 7 and 8 inputs, but I can't figure out how to set it up in the session. I've tried sending from the master and routing back in through a stereo audio track, a stereo aux track. I"ve set it up as a bus and busses all my track individually, and used the bus as a "send," then routed the signal coming back to another bus as the "return," which means that I have 2 aux tracks AND the master. There's got to be a better way. Please, somebody show me the way!
Re: How can I insert a hardware effect into my master track?
Use the inserts at the top of your channel in the mix window.
It should be the same as inserting on any other channel. If you have your manual, check the index on inserts. |
well, don't I feel silly now. Thanks, that works great.
hardware effect insert | rorez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 03-13-2010 10:51 PM |
Hardware insert--No audio going to 1-2 master fader. | Paul Cavins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 11-06-2008 04:59 PM |
Question about effect insert levels on track mix view | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-20-2007 07:20 PM |
Using REaktor as an insert effect | Ford | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-15-2006 11:49 AM |
Hardware insert on master fader feeds back? | KK Proffitt | Pro Tools TDM Systems (Mac) | 6 | 03-19-2004 01:53 PM |
