Old 06-21-2015, 06:42 PM
bredo bredo is offline
Default My Parametric Eq Settings changed
The settings on the parametric eq have changed across all patches. The Q-value of the 3 upper bands + the Eq type on the lowest band (HP filter type reset to HP24 and Q= 0.7).
Anyone else had this?
PS. This is for presets/patches I have used for a long time.
Anybody has a clue?
Old 06-22-2015, 07:48 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: My Parametric Eq Settings changed
Are you seeing this in the Editor or on the Rack itself?
I mentioned something like this awhile back in a video. Is this the same issue you are talking about?
https://www.youtube.com/watch?v=u0LUa9C_zb4
Brian
Windows 10 Pro 64 Bit
Pro Tools 2021
benonistudio.com
Plugin Deals
@benonistudio
Instagram
Old 06-22-2015, 11:01 AM
Thank you very much Sir.
This was it for the Q values. But...
... But one other thing I noticed was the change/reset of the HP filter slope.
For patches I know I have used HP6, it reset to HP24...... With the end result of removing much/all low end (due to the steeper filter).
Some other patches I could hear a difference, resulting in a "duller" sound.
Thanks again. I will check some more.
Old 06-22-2015, 11:14 AM
Benoni's Avatar
The changing of the filter types is something I have not seen. Is it every patch? Do you notice any similarities between those patches... like, do they all use a certain amp, or effect, or something?
Brian
Pro Tools 2021
benonistudio.com
Plugin Deals
@benonistudio
Instagram
Old 06-22-2015, 03:34 PM
I have narrowed it down to: When I load some of my own Eq presets (that I know I had the HP6 setting) they open up with the HP24 filter. Hmmm, strange.
No big deal though, as I just can change the filter type.
PS. I may have to re-save my presets after the change. I will try that, and see what happens.
Thanks again.
I/O settings changed Adept Pro Tools 9 5 03-07-2012 04:57 PM
More 11R Parametric EQ settings Deny Eleven Rack 6 06-24-2011 06:00 AM
Parametric EQ Settings brianiac5150 Eleven Rack 0 03-23-2011 07:27 AM
I/O Settings Changed??? Please Help!! TeleKing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-20-2004 05:42 PM
I/O settings changed? Elvisaintme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-31-2004 11:32 PM
