Help needed urgent!!
Hello!
I have a problem that I need to solve quicker than quick. I recently bought a Digi 001, so i´m just starting to get the hang of it. The problem: yesterday, me and a friend were tracking some piano and drums, I created a send so we would be able to hear the piano (and not the drums). The problem is that I get no sound from the piano when i´m in record mode and have low latency mode turned on. When I turn low latency off, I hear the sound perfect, but with a delay offcourse. I just can´t believe that it´s not working, since this is something very fundamental when you are recording!!? Is it supposed to be this way??? if it is, I am deeply dissapointed... My system: Digi 001, v5.3.1.
Macbook Pro 2Ghz, 2Gb ram. 002r |
Re: Help needed urgent!!
Check that monitoring is set to "input only" and not "auto input". I know low latency mode bypasses all plug-in so if your piano is a plug-in then you're SOL. If its a module you should be fine. Regardless, set hardware buffer latency to 256 or better 128 and if you don't experience dropouts, you will hear No latnecy.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
Auxes don't work in Low Latency mode. The solution is a cheap mixer for monitoring.
Thanks!! it works great now!
Urgent help is needed | Labze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 07-04-2009 08:48 AM |
URGENT HELP NEEDED! | roxymusik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-23-2007 12:13 PM |
Urgent Help Needed!!! | ichbin | Pro Tools TDM Systems (Mac) | 2 | 11-18-2007 01:19 PM |
Urgent...help needed...please | lemix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-15-2004 08:25 AM |
URGENT HELP NEEDED | rschweng | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-17-2002 03:18 PM |
