Old 01-09-2016, 12:21 PM
biasrocks biasrocks is offline
Default V12.4 Commit through hardware, latency issue
I'm having latency issue's when committing a track containing a hardware insert with 12.4.
The track is perfectly phase aligned when playing the live insert back, but when committed there's noticeable phase incoherence.
I'm bussing the drum tracks to one AUX, "Drum.Bus", this has a pre-fade send to the parallel compressed track "Drum.Bus.pl"
which includes the hardware insert.
Anyone having this issue?
I've included two MP3 files, one of the live track and then of the committed track. I've also included two screen shots, before and after.
Rename .pdf to .mp3 to play the audio files.
Mark
Sharktankpro.com
Old 01-11-2016, 02:56 PM
Default Re: V12.4 Commit through hardware, latency issue
I went back to 12.3.1 and the problem stilll exists, but the actual offset is smaller on this version compared to 12.4.
Somethings going on.
Mark
Old 01-11-2016, 05:03 PM
YYR123's Avatar
YYR123 YYR123 is offline
So you're doing the commit in real time obviously and you have the off-line button unchecked
Do you see any difference when you actually bounce the the track in real-time to the external hardware?
Daniel
Old 01-12-2016, 08:29 AM
Yes in real time and the offline button is greyed out.
I will try a bounce and see if there's any difference.
Mark
Old 01-12-2016, 09:47 AM
A real time bounce results in the same issue.
Rock solid phase when running live, in parallel, gone when committed or bounced.
Mark
Old 01-12-2016, 10:54 AM
YYR123's Avatar
What's your buffer set to, out of curiosity?
Track delay compensation?
Interface?
Daniel
Old 01-12-2016, 12:27 PM
I'm running 48kHz through Apogee 16X's.
Hardware Insert Delay is set to 1.22ms as Apogee recommends.
Buffer set to 32 resulted in the same offset as running at 1024.
Delay compensation is turned on.
Mark
Old 01-12-2016, 12:42 PM
ptr22 ptr22 is offline
How's printing back into the session going? Is that okay? Solved issues for me over online and offline prints.
Old 01-12-2016, 02:38 PM
Printing through the session into an audio track works as expected, no issues.
Mark
Old 11-21-2016, 06:08 AM
SimonN SimonN is offline
Got this to work eventually? I have a solution (although not an explanation) if not.
PT 12.3 kontakt ONLY so far commit issue john1192 Pro Tools 12 9 11-10-2015 06:39 PM
Hardware Insert Latency issue in Pro Tools 10!!! HELP !!! Hovak macOS 14 10-28-2012 10:42 AM
To Commit or not to Commit, that is the question. georgejw22 Pro Tools 10 10 12-20-2011 05:30 AM
Patching in compressor hardware latency issue willl3 Windows 1 09-14-2011 07:36 AM
Latency issue with PT7.1 & Hardware Synth TonyBer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-02-2006 08:21 AM
