96 k buffer problems
we are using protools le 7.3 ,and have started recording in 96k now we have to turn the buffer all the way up. this is causing latence problems . what can we do...
Re: 96 k buffer problems
Every time you increase the sampling rate in which you are recording, you also increase the amount of processing power/disk space required to run a session. It takes double the CPU power to run a reverb at 96k as it does 48k. You need to ask yourself why do you need to record at such a high rate? If you are going to CD or even MP3 you could argue its not worth the hit taken on your system.
At 96k, you will not be able to run as many tracks with plugins as well as the possibility of needing two drives for one session if it gets large. The Buffer? You take some pressure off the CPU when you increase the buffer. Thats why it can now run at a higher setting, useless for tracking but for mixing is fine. If you must record at 96k...try turning off as many plugins as possible and lower the buffer until you find a sweet spot. J
ProTools 2018 1 x Apollo Quad Firewire 1 x Apogee Duet 2 mac/ios MacBook Pro (15-inch,2018) 2.9 Ghz Intel Core i9 CPU 32 GB 2400 DDR4 RAM 1TB SSD System Drive Mac OS High Sierra 10.13.6 |
thanks,
Or try Low Latency Monitoring when you are recording. All plug-ins will be put in bypass.
Cheers,
Buffer Problems, Need Help | Mschmid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 06-12-2009 09:09 PM |
Buffer Problems!! | jimidalliance | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-24-2008 12:51 PM |
Buffer Errors / Buffer Problems? | freezegelman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-28-2006 11:50 AM |
buffer problems | badda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-11-2006 10:26 AM |
HW Buffer problems still here! | Sonny Boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-14-2006 03:44 AM |
