Old 02-24-2012, 06:43 PM
RichWilley RichWilley is offline
Default Mic "suddenly" stopped working
I'm using PT10 with M-Audio Fast Track Pro on a Windows 7 computer. My mic is an EV RE20, about a month old.
Today I recorded several tracks and everything was going pretty well except for some static.
I looked up static here and found a post where a guy used compressed air to clean all the connections on his Fast Track Pro, so I did that, and ever since I have no mic through either channel.
Was that the cause, or is it just a coincidence and I'm not seeing what's really going on?
Thanks in advance.
Old 02-24-2012, 08:52 PM
Default Re: Mic "suddenly" stopped working
Static and distortion is about all I get from my Fast Track Pro in PT9. I think M-Audio needs to deliver a better driver(it works fine in MP8).
Old 02-25-2012, 05:01 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Check that you don't have phantom power (48v) applied.
RE20 is one of the only dynamic mics that seems to go screwy when you feed it phantom.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 02-25-2012, 05:25 AM
Phantom power is off.
In Pro Tools it doesn't even allow me to choose Input 1 or Input 2. Is that an indicator that the Fast Track Pro is malfunctioning? I've tried my mic in both channels and it doesn't make any difference, I'm not able to access it.
Thanks for helping . . . I'm so new at this and frustrated like you can't imagine.
Old 02-25-2012, 11:19 AM
Check under the Hardware menu to see that the Fast Track is the selected audio engine.
Old 02-25-2012, 01:58 PM
Yes, it's been set that way all along. A buddy of mine who runs a recording studio in town is coming over tomorrow to see if he can figure it all out. In the course of our phone conversation it sounds to him like everything ought to work . . . yet it doesn't.
More will be revealed.
I appreciate all the help!
Old 02-25-2012, 02:48 PM
The Weed's Avatar
The Weed The Weed is offline
Try "Defaulting" the I/O setup in Pro Tools.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-25-2012, 03:38 PM
Cheers,
You are a GENIUS!!! That worked like magic . . . I haven't been this happy in . . . well, in a long time.
Thank you so much!
Thank you, thank you, thank you, and THANK YOU!!!
Old 02-26-2012, 04:52 AM
panamajack's Avatar
panamajack panamajack is offline
Originally Posted by RichWilley View Post
... I ... found a post where a guy used compressed air to clean all the connections ..., so I did that, and ever since I have no mic through either channel...
Do you think the compressed air blast changed your setup for I/O connections?
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 02-26-2012, 05:13 AM
mano111 mano111 is offline
Originally Posted by panamajack View Post
do you think the compressed air blast changed your setup for i/o connections?
:d:d:d
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
FastTrack Ultra 8R stopped working - have tried "everything"! trumling Pro Tools M-Powered (Mac) 2 03-15-2015 10:18 AM
"Pro Tools application has stopped working" Sandra report inside... JLiRD808 Windows 2 09-15-2012 08:27 AM
need help"Pro Tools Application has stopped working" cab7220 Windows 12 05-16-2011 11:11 PM
"Next start/end"- shortcut stopped working...? renbak Pro Tools TDM Systems (Mac) 6 12-07-2010 01:59 AM
Transfuser stopped working: "set the correct path on set up page" dannielexists Virtual Instruments 2 09-16-2010 05:37 PM
