help with hd 7.4 - nuendo mtc sync problem
Hi
I just upgraded my pt software from 6.9 to 7.4 and now im having a problem with mtc. im trying to sync pt to nuendo via mtc. problem- everything is running fine at first but after about 10 sec nuendo stops syncing with pt for about 2 sec. after this happens nuendo starts again but is now out of sync with pt.(its 2 sec behind). is this a common bug in 7.4? ps. i havent changed the nuendo settings at all just pt. cheers steve |
Re: help with hd 7.4 - nuendo mtc sync problem
"problem-
everything is running fine at first but after about 10 sec nuendo stops syncing with pt for about 2 sec. after this happens nuendo starts again but is now out of sync with pt.(its 2 sec behind)." ...is nuendo master or slave? you said "nuendo stops syncing" , it stops sending mtc or stops playback or PT looses sync? its not very clear what your setup is.... normally i use nuendo as slave to PT but i use MMC via an midi cable which works very well.
foley artist , soundeditor |
i want pt to be the master and nuendo to be the slave. ive done this many times and its worked great.
the prob is that nuendo looses sync 10 sec after it starts , so if i hit play on pt nuendo syncs fine but 10 sec in nuendo looses sync and pauses for a sec or 2. after this nuendo begins syncing again but now its 2 sec behind due to the pause.it doesnt matter where i am when i hit play it will happen after 10 sec. all the settings are matched up in both computers. when i switch it from 30fps tp 24fps (on both computers) the pause in sync happens at around 8 sec from when i hit play. |
since i am on PT 6.41 (Mix not HD) and i use Nuendo 4
(which version you have?) i cannot say whats wrong. normally i use MMC which works ... did you installed the latest cs for PT 7.4 maybe there is a problem.. regards
Problem with Windows 7 64 bit / Nuendo 32 bit / EuControl 2.5.7 | Klosse | Artist Series | 2 | 12-07-2011 02:50 PM |
Problem when using Nuendo 3! | kieuphucuong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-22-2008 03:48 PM |
Sync issues....PT and Nuendo | elementsound | Pro Tools TDM Systems (Mac) | 1 | 09-06-2004 01:29 AM |
Problem opening Nuendo 2 OMF in DigiTranslator | jdaboll | Pro Tools TDM Systems (Mac) | 6 | 05-26-2004 08:33 PM |
How to sync Protools with Nuendo. | Jayman#9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-07-2002 05:09 AM |
