SPACE plugin : PT 2021 does not load correct IR
Hello
i'm having issues with the Space plugin : if i save the session with PTHD10 (TDM) and then open it with PT 2021, it does not load correct IR but some default IRs instead.
My soundcloud page Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8 |
Re: SPACE plugin : PT 2021 does not load correct IR
Did you try opening the session more than once? because that plugin always fails to load correctly on the first try for me. I can open the same session over and over again and it fails to load settings sometimes. If you save after it failed to load correctly, the settings are gone forever.
Make sure to open a support case if we are to have any hope of it getting fixed. |
understood
thank you for shiming in i'll let you know about it once i opened a support ticket and get an answer
Unfortunately there has been lots of problems with Space, even when it was Trillium Labs plugin. It may even load the correct IR but have left channel on every channel. Would not bet on it, or if used make sure print it when it sounds as it should.
i've opened a ticket because this is not the only issue :
- pro tools does not undo on plugins anymore - pro tools does not save every minutes as set in the prefs regarding the space ir i'm always using the same set of 8 or 10 ir so it's no big deal. It just forces me to duplicate the last saved PTHD10 tdm session and open it in PT2021. Annoying but no big deal.
Protools 2021.3.1 slow to load and then freezes | BarefootWarrior | Pro Tools | 0 | 04-22-2021 08:59 AM |
Space plugin fails to load in 2020 | doc838 | Licensing & Accounts | 2 | 01-16-2020 08:43 AM |
Correct Load Order for ReWire Applications | Digital Heaven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-02-2004 05:08 PM |
Pro tools does not load the correct REason session | firedog57 | Pro Tools TDM Systems (Mac) | 6 | 03-25-2004 09:23 AM |
