Benchmark DAC1?
How would be the best way to run this unit off my 192i/0? I would like to use this unit as my D/A for monitoring audio when I am mixing thru my Genelec 8040s. Also would I be loosing delay compensation with my Protools HD rig? Anyone using this with their Protools system with stellar results? Thank's.
Re: Benchmark DAC1?
I have it hooked up like this:
192 I/O (Enclosured AES/EBU) -> DAC1 -> Dynaudio BM9 Sub -> Genelec 1030A's It works great. Make sure to flip the switch to "Variable" on the back panel. You don't want to blow your speakers. This mode lets you control output level with the front panel gain knob. ADC works perfectly, no worries.
Re: Benchmark DAC1?
Ditto about it being great. Personally, I found the factory output gain setting to be inadequate when mixing without using a limiter across the mix buss. Thankfully, the gain can be adjusted by moving internal jumpers. I moved mine to the middle setting and am now perfectly happy. Check the manual for details.
Re: Benchmark DAC1?
First off, Thank you so much for your thoughts and insight on this soon to be new addition to my rig! Can anybody comment on how the unit sounds versus just using the 192i/o for the D/A? Also does the volume knob on the unit work well if you are going to use it for your main monitor level control?
Re: Benchmark DAC1?
Hi Durka,
I'm using a 192I/O with a Benchmark DAC-1 D/A also. I've had mine for about 2 years. I've made little marks along the face for my volume knob calibrations i.e. 85db for mastering, and various other monitoring levels when I'm tracking and mixing. Great piece of gear!! G5 Dual 2.3ghz, 4.5gig ram, PT 7.1.cs4, Magma 7 Slot 32bit 33mhz Expansion Chassis with HD Core, HD Accel, and 5 HD Process cards Randy
Mac Pro Early 2009 3.06 Six Core 48gb ram, Pro Tools 10.3.10, HD6 Accel, Pro Tools 2021, Macbook Pro, Magma PE6R4i, Yamaha DM2000 Console, Logic 9 and 10, Apogee Big Ben, 10pcs HD 192's, Benchmark DAC-1, Distressors, API, Neve, Rupert Neve, Dangerous, Lynx, Manley ELOP+, Massive Passive, VariMu, Neumann, Peluso, A-Designs Hammer 2 & Nail, Empirical Labs, Drawmer, Lexicon U87, Bricasti M7, dbx, Cranesong, SSL 500 G-Bus, Custom Audio Germany, Dynaudio, Focal, Yamaha, TC Electronic, Mapex Drums, SPL |
Re: Benchmark DAC1?
I've had mine for about a year or so..but am about to set up for 5.1..guess I'll have to bypass this gem.
Eleven Rack & Benchmark DAC1 USb connection | DeButte | General Discussion | 4 | 12-01-2011 02:19 PM |
Benchmark DAC1 or Coleman Audio TB3? | toneski | Pro Tools TDM Systems (Mac) | 4 | 04-02-2007 10:48 AM |
benchmark dac1 via spdif out on mbox 2 | tree montgomery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-26-2006 06:23 PM |
Connecting Lightpipe out to Benchmark DAC1 | new engineer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-08-2004 11:46 AM |
Benchmark DAC1 | M Lawrence | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-25-2002 01:19 AM |
