Help system won't come up
I'm not one of the mixer I work in IT, but the Venue won't come up and I need help. It has happened a couple times recently. Bring up the system and I have double-check and using the correct order. Everything appears fine but get no sound from mains instead this clicking and frying sound. Monitors usually come up though. Until today the fix was to take whole system down and then restart and things would be fine. Today the clicking and buzzing never stopped and system wasn't usable.
I don't know much about the system trying to contact the main audio person. In mean time anything I can check? It is an Venue with sidecar in a permanent installation. I believe it is about three years old. It it helps we have Pro Tools connected and started the recording and could see the noise being sent to PT. Think it could be things just need to be reseated?
Steve B. ---------------------------------------------------------------- If you think you can or if you think you can't, you're right. |
Re: Help system won't come up
Hi Steve,
I'm sorry to hear about your troubles. Please call the VENUE support line at 650.731.6111. They can help troubleshoot and diagnose the problem. Sheldon |
Thanks for the number. The main audio person is on there way in and we will call together since he knows the details they will want to know.
System Requirements and full System Setup | MadDogRunner | Windows | 2 | 02-25-2013 05:44 PM |
D-Show system with power sequencer/relay system. | TheatreWeasel | VENUE Live Sound Systems | 2 | 01-15-2012 03:35 PM |
Good System Usage/RTAS settings for Quad Core system | Mental Clarity | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-19-2008 03:09 PM |
Fat 32 IDE rmoveable drives (from WIN98SE system) not accessable from XP system | steve at Your Heaven | Pro Tools TDM Systems (Win) | 7 | 06-12-2003 12:17 AM |
New Allenstein system.... Radeon 7500 causes system to lock up.. | Siberian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 03-09-2003 07:23 PM |
