#41
Re: 7.4 LE MIDI BEAT CLOCK works !!!!
#42
Look at my set Up : I never had your problem with MBC........ all my gears runs at the good tempo............ and since V6.4 !!!!
Did you tried v7.3 before??,
MACPRO BI 2,66 +5Go RAM+ OS 10.6.8 FRENCH SYSTEM + DIGI002 RACK Protools 9.06 www.myspace.com/alx002 |
#43
Any news?????
Ho YEs I forgot !!! Don't expect to have the V 7.4 working better !!!!! STill this bug in V7.4.......
#44
Re: Protools 7.3 LE STILL BAD MIDI BEAT CLOCK
Hi DIGITECH!!!! What's about the MIDI BEAT CLOCK !!!!! Do it will be fixed ONE DAY???
#45
Hi Protools USERS!!!
Protools8 will come soon!!!! So A new thread will be open about that problem!!!
#46
Here's the explanation of behavior of MBC in Pro Tools:
MBC Looping Pro Tools currently loops around MIDI Beat Clock (MBC) when playing in a loop. This feature is needed for instrument plug-ins with built-in sequencers or processing algorithms that rely on looped MBC messages for accurate operation, for example Synchronic. While most external devices should not have a problem with quick jumps of Song Position Pointer (SPP) messages, certain hardware sequencers will behave erratically at the loop point. The exact MIDI event sequence at the loop point is as follows: <Stop> <Song Position Pointer> (pointing to the loop start location) <Continue> Other sequencer applications on the market today solve this problem by not looping MBC signals at all, i.e. even though the internal transport will play in a loop the MBC clock signal will continue “straight” and not contain SPP messages. Susceptible hardware sequencers will thus run without hiccups. We are looking to introduce a preference that will allow users to switch between looped and unlooped MBC clock. Even though we’re well aware of the severity of this issue for some users we cannot discuss a release timeframe at this time. Thank you for your understanding and your continued support! |
#47
I'm still waiting for this preference to be implemented. So I won't buy PT8 for this moment
#48
Re: Protools 8 LE STILL BAD MIDI BEAT CLOCK
Hey guys from AVID ;-)
Are you still working of this new awaited feature for MBC ? Thx Alex
#49
Hi Alx,
i don't know if you're still here or if you solved your problem with Pro tools, but i am on PT 12... and i have the same problem with my drum machines You know if this problem was finally solved by Pro Tools ? Thanks for your answer, Cheers. mattia |
MIDI Beat Clock? | guitarless | Eleven Rack | 3 | 10-24-2010 03:39 PM |
Pro Tools Slaved by Midi Time Code or Midi Beat Clock | DarylBham | MIDI | 5 | 06-14-2009 01:55 PM |
Triton...is MIDI Clock difrnt than MIDI Beat Clock | BookSix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-12-2006 12:24 AM |
Slaving ProTools with Beat clock | cybernaga595 | MIDI | 1 | 03-28-2004 05:12 PM |
Protools Lock To MTC or Midi Beat Clock? | nozza1 | Pro Tools TDM Systems (Mac) | 10 | 05-30-2001 03:30 PM |
