midi problem
Hi guys, I have two midi instruments (Yamaha PF100 Piano and Roland TD9 electronic drums) I record the PF100 via my Profre2626 Midi In, and the Roland TD9 drums via a Midi to USB converter.
Until recently it was working perfectly...Now when I record them, each track records both instruments. I've tried deleting the two Midi Tracks and setting them up again to no avail. The problem seems to have arisen since I used my Axiom midi controller (USB) which has since been removed both physically and from PT9... The K/B is on Ch1 and the Drums on Ch10...and the Midi Tracks set up accordingly. Any advice and suggestions welcomed. Kind Regards PT9 Macbook Pro 4 core 8GB RAM OWC Mercury Elite Pro 2TB Ext HD M-Audio Profire 2626 |
Re: midi problem
As a suppliment to my question (it seems that my situation is unique). Would it be advisable to re-install PT9 and put the problem down to the inexactitude of software? Any thoughts? Cheers
Re: midi problem
Its more likely that your Midi Studio config is messed up. Here is what worked for me with a TD-10 kit, Motif es8 and a 3rd keyboard(used for organ). In Midi Studio, I created 3 instruments. Each had the midi input port selected(TD-10 kit on 003 midi input, Motif on MOTU Fastlane USB port B, 3rd keyboard on MOTU input A. TD-10 kit used midi channel 10 only. Motif used all 16 and 3rd keyboard used only channel 1. In a session, I put up 3 stereo instrument tracks. Inserted EZdrummer, MiniGrand and DB-33 on the 3 tracks(always using slot A). With MIX window set to show Instruments(under the VIEW menu) and set the incoming midi source to the desired controller(TD-10, Motif or keyboard). Enable RECORD on all 3(hold the Alt key and select any one RECORD button) and each instrument would be "played" by only its desired controller. Last 2 details to set; Midi Thru should be ON and, in preferences, set the default Midi Instrument to NONE.
Remember, in Midi Studio settings, the Brand and Model are NOT crucial(can be left blank or select anything).
Problem: Recording Electric Drums via Midi with Addictive Drums (Latency problem) | Don Bravo | General Discussion | 5 | 07-04-2014 11:49 PM |
[Problem] Midi Pro Tools 10.3.5 & Motu Midi Express 128 | Advanced-Productions | MIDI | 0 | 05-20-2013 09:43 AM |
Midi problem - no INPUT DEVICE option in MIDI menu | tam103 | MIDI | 2 | 01-05-2007 08:01 AM |
MIDI problem...can't change patch / hear MIDI | missmason | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-05-2006 09:43 PM |
MIDI Output Problem - Assigning MIDI Patch Names | pancake1975 | MIDI | 8 | 05-29-2006 03:25 PM |
