Routing Question
Hey guys,
Got a question about routing. I have all my tracks and auxes and what not routed to an aux call PRINT I do all my 2 bus processing there. Print goes out into another aux I call WRITE which I use to record the whole mix onto a track. And then I have my usual master fader. For some reason both PRINT and WRITE peak a -0.1 which is the ceiling on my limiter, yet my master fader goes over up to around 3 at some point. I have attached a screenshot from my buses. FWIW my session is a 48k which I read somewhere might cause the overs which makes absolutely no sense to me. Thanks |
Re: Routing Question
Something else might be outputting to Mon 1-2. When you mute the WRITE aux, is there still meter movement on Master 1?
Any particular reason you have PROQ2 and PRO-L on the second bank of inserts? Why not just put them right after whatever 'track control' plugin is. Why do you have two of the same plugin? Have you tried using oversampling on the PRO-L? The usual sequence I use on my 2-bus aux is an compressor, limiter, and metering plugin. If I need an eq I put it after the compressor that way the comp isn't fighting the eq changes. edit for additional: What level is your master fader set to? Last edited by musicman691; 11-30-2017 at 06:25 PM. |
I swear I clicked on "Select assignments to Mon 1-2" and double checked a million times before posting here, but oh well..., thanks to your post I pulled up the session again and found there was one track still routed to Mon 1-2... Thanks again!!! Quote:
The last slot I always use for loudness metering which I hadn't inserted yet. Quote:
Thanks guys this is now solved!! |
003 Routing Question | Top Secret Productions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-19-2016 01:58 PM |
Routing question ? | Raoul23 | Tips & Tricks | 15 | 03-21-2013 02:39 AM |
Routing question -- how can I do this? | WildHoney | Pro Tools TDM Systems (Mac) | 6 | 08-15-2006 04:44 PM |
Routing question... | sweetpee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-16-2005 05:01 PM |
001 Cue Mix Routing Question | Nash BBQ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 10-03-2002 10:03 AM |
