Seems pretty solid here... Been rolling on it pretty tough for half of the day...
Sent from my SPH-L710 using Tapatalk 2
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' NO, SHE'S WITH HOBO KEY '' (that dopey green thing) ('we' must start using pronouns) |
Re: 10.3.2 is Here
Do I see a Keybeeetsss?!
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Re: 10.3.2 is Here
works fine here, finally automation point thingy was fixed. im happy with this update
www.dominicdotokune.com |
Re: 10.3.2 is Here
Still having the problem with nudging breakpoints, doesn't matter if "automation follows edit" is on or off. Not happening when I nudge clips, only when nudging the actual automation points it creates new points.
PTHD 10.3.2 on OSX 10.7.4. |
Re: 10.3.2 is Here
I loaded up Protools 10.3.2 on both my MacPro and my Macbook Pro and it seems to be running fine so far. There doesn't seem to be an Virtual Instrument Installer this time like it did with 10.3.0 (and 10.3.1 used the same Virtual Instrument Installer as 10.3.0).
I read the "what is fixed in this version" and although the fixes are significant to many people, this was a relative minor release in that only a few bugs were fixed. Before someone jumps down my throat. I'm not saying the fixes are not important. I'm just saying that the number of fixes are few.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Re: 10.3.2 is Here
Re: 10.3.2 is Here
That breakpoint bug was a pain when trying to edit what I thought was a track with no automation. Simple to take care of but a pain nonetheless. I thought the way the Dynamic Transport is working now was a bug! I got used to having it go to the beginning but didn't like it when selecting a long single clip. It's better the way it is. Then I learned "Alt [" .
Automation breakpoints are no longer added unnecessarily when editing clips with Automation Follows Edit turned on. (PTSW-173028) In Dynamic Transport mode with Link Timeline and Edit Selection enabled, the playhead no longer moves to beginning of the selection. (PTSW-172367) Clicking the Automation Follows Edit button now correctly causes the current selection to update to reflect the new state of the button. (PTSW-170044)[/QUOTE] I installed it
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
Re: 10.3.2 is Here
But do you need to reinstall the VI's if you're still on 10.2 and doing the update to 10.3.2?
Nub question inc!
Does this work on the new mountain lion? |
