IRQ/Performance Questions
Hey Guys
WinXP has put my 001 card in IRQ 15 (on its own), and my promise card in IRQ 14 (on its own). There are some earlier IRQs free but the recording comp is 30 mins drive from me at the moment so I can't give a full list at this stage. Is this OK? At this stage I think I'm getting a slight drop in performance from 5.1.1 on Win98. I've got an AthlonXp 1600 on a Gigabyte GA-7ZXE mobo. 512MB PC-133 RAM. System drive is on onboard IDE1, CDRW is on onboard IDE2, and 2 audios drives are on one Promise port each. PCI cards..... Slot 1 - Empty Slot 2 - Yamaha sound card Slot 3 - Promise ATA100 IDE controller Slot 4 - DIGI001 Slot 5 - Firewire card Slot 6 - Empty There is also no option the enable DMA on the Promise card drives. Is this normal? Are there any WinXP tweaks I need to do? All suggestions greatfully received. Thanks Mark
http://www.oneearthproductions.net |
Re: IRQ/Performance Questions
Bump [img]images/icons/frown.gif[/img]
Aussie169,
One of the beta testers told me there IS a very slight drop in performance in this new system (on the Davec test, for example, maybe a few less Aux. tracks than before). I do not know about the best IRQ positions yet. ~Roy
rh music |
My Gigabyte GA7DXR+ with XP set the IRQ's the same way. I lost one track with XP on the DaveC test... My system seems very stable. The only hiccup is when I first start digi somethimes it doesn't start, I just see a flicker the I have to restart the program. The only minor problem so far... Any of the beta testers have an answer to the IRQ question? |
(I gained 4 tracks in Davec, from 15 to 19 on my Tbird 750). Peter |
Mark,
I need to research the hardware priority given to these new IRQs. When you get a chance, if you could list what you're getting it would help. I have a lot of experience with another application under both XP and ME - Seti@Home. I've completed nearly 11,000 Seti@Home work units. I can tell you that the very same machine, when converted from Win ME to Win XP Home, dropped it's Seti@Home performance, on the average, buy about 4%. If PTLE had a similar drop, that could account for 1-2 tracks. Mark |
How much Ram is too much? + drive performance questions | BusyBoxSt7 | Pro Tools TDM Systems (Mac) | 16 | 10-15-2009 08:37 PM |
Go big or go home, or don't waste the cash? Mac Pro performance questions!! | MetalbrookAudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-14-2009 10:28 PM |
Mac Mini Ram and performance questions | ZEUSS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-20-2007 05:12 PM |
PCMIA Card/ CPU performance questions | Rob Ruce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-01-2004 01:38 PM |
A couple of performance questions... | Col. Kurtz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-21-2000 01:21 PM |
