Old 10-09-2007, 10:35 AM
Tim R. Tim R. is offline
Default 5.1 Surround processing (vs. linked mono/stereo)
What is gained by using a true "Surround-5.1" plugin (dynamics mainly) as apposed to a mulimono plugin with certain channels linked?
What are you using for dynamics on your 5.1 output?
Tim
Tim Reisig
System 1: Pro Tools Ultimate 2021.10, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 21.10, Rosetta 800 w/XHD card
Mac OS 10.15.7, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2020.6 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Old 10-09-2007, 11:11 AM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Re: 5.1 Surround processing (vs. linked mono/stereo)
Some plug-ins only exist as multi-mono. Sometimes multi-mono is really useful, say when you want a hi-pass filter on the LFE track.
I have used McDSP G Dynamics 5.1 compressors, and also Digi-Rack 5.1 for mix buss compressors.
noise | jimlongo
Old 10-09-2007, 12:24 PM
I can see the advantage of multi-mono, but what's the advantage of a true 5.1 version?
Tim
Tim Reisig
Old 10-09-2007, 12:43 PM
geitz geitz is offline
What comes immediately to mind is dynamics processing. In a multi-channel plugin there's a common detector "circuit" that causes the comp, limiter, etc. to act on all channels equally when any of them exceeds the threshold. For instance, the dialog in the center channel exceeding the threshold would cause all channels to be compressed equally, maintaining relative balance among all channels. In a multi-mono plugin, each channel has it's own detector circuit so balance among channels will be all over the place.
Greg Geitzenauer
Babble-On Recording Studios
Greg Geitzenauer
mixer/editor
Rumble
Minneapolis, MN
HTML code is On
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 09:01 AM
Mono/stereo Stereo mono..... What happen here ? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-18-2004 09:28 AM
stereo file to mono and mono too stereo ? surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-19-2003 07:52 PM
