DAE error 9131- no playback in Pro Tools
Help. I just purchased a Lacie Firewire drive and I need to start this project on Monday! I get the above dae error when I want to playback in Pro Tools. The answerbase says to reformat the drive in Disk Utilities but this does not solve the problem. Is there anything I can do?
Thanks for any advice. Kevin |
Re: DAE error 9131- no playback in Pro Tools
Which OS version are you running? There were some known issues with 10.3.3 and LaCie drives...
Is this a FW400 or FW800 drive? FW800 drives are not supported. If this drive is very large (>200gb) you may want to try partitioning the drive into two smaller partitions. |
I have had this problem..
Check to make sure the new drive is highlighted correctly when you go to format it. For example, the menu will show something like LACIE FW.... and underneath it will show something similar. LACIE 140 GB _____LACIEXXX... Make sure that you highlight the TOP one Worked for me and a few friends! The Lacie's are very sturdy performers! One of mine (Porsche)took a SERIOUS drop and keeps running! |
I had this same problem on a Porsche drive I have. One works okay...the other with this error message. No matter what, no dice. I got a D2 and no problem. The Porsche is now just a backup drive, but I can't play from it.
DId the formatting process I described look familiar?
I have about 7 of them and only had this problem when I formatted the wrong way. Guess you can't test it since you are using it for backup. They're on sale now at Comp USA... 160 GB for $120 bucks! |
DAE error -9131 Pro Tools LE | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-13-2006 01:46 PM |
DAE Error -9131.... Yes, the dreaded -9131. | defconnect5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 08-06-2006 06:54 AM |
Pro Tools 6.4 - DAE -9131 error | napoleantnt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 07-01-2006 04:00 PM |
DAE error 9131 | legitmik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-25-2005 07:18 AM |
DAE error 9131 on playback | Buzz Moschetti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-10-2001 06:40 AM |
