Old 03-04-2003, 01:46 PM
eddybertrand eddybertrand is offline
Default My hard drive does not appear on desktop
I have an extra ATA hard Drive named PTLE & it's where I Store all my Pro tools sessions.
Last time I was working on a session and accidently put to sleep my computer, when I tried to wake the computer hardDrive I wasnot able to record or even save session, so I had to restart the computer, when restarting I was listenig to a wierd noise like cracking on & off and Desktop appears the "PTLE HardDrive" was gone, I tried anythingthing to find It, even with Norton, Doctor, Firstaid, It just does not appear.
If any of you had any similar expirience I would appreciate your help.
I'm lost
Thanks Eddy [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img]
eddy
Old 03-04-2003, 02:39 PM
Default Re: My hard drive does not appear on desktop
[QUOTE]Originally posted by eddybertrand:
[QB] I have an extra ATA hard Drive named PTLE & it's where I Store all my Pro tools sessions.
I'm lost
eddy
Old 03-04-2003, 02:53 PM
Knock Knonk Knock
eddy
Old 03-04-2003, 02:54 PM
Calebjess Calebjess is offline
The noises you described are not encouraging. Sometimes when a hard drive fails it will make noises (extra clicking etc). This has happened to me at work with my IBM laptop. I dont run PT on the IBM though. How did you connect your ATA HD? Is it external or internal? If internal: Did you add it to the extra IDE plug or did you have to add a PCI EIDE card to connect to the HD? Or is it by SCSI (skuzzy)? I added a 40gig Maxtor HD to my rev 1 G3 using an EIDE PCI card over 2 years ago w/no problems. Newer Macs come with the IDE controller that you can just plug an extra HD into. However it is connected there will be some system folder/set program that can check to see if the drive is working.
Knock Knonk Knock
eddy
Old 03-04-2003, 02:57 PM
jgehring jgehring is offline
That drive may have died for some reason - I've seen it before for all kinds of reasons. I'd suggest disconnecting the music drive (both IDE & power), powering up the machine, then shutting it down & reconnecting it to see if it will redetect the drive. Then I would suggest turning off sleep.
Pro Tools HD 11.3.1 on OSX 10.9.5
HD Native
Mac Pro 5,1, 32GB, OWC drives
www.architectsoftheaftermath.com steals your soul while you sleep
Old 03-04-2003, 03:01 PM
<font size="2" face="Verdana, Arial">Actually It's an internal HardDrive,I added it to the extra IDE plug & bought it last year, I defragmented once a month
Eddy
eddy
Old 03-04-2003, 03:09 PM
Originally posted by probetools:
sounds like it became unmounted. try to mount it again. check system profile and see if its mounted.
<font size="2" face="Verdana, Arial">How do I mount it if it's unmounted
eddy
Main Hard Drive Dissapeared from Desktop guitar012001 Pro Tools TDM Systems (Mac) 0 06-02-2010 09:08 AM
DAE can't get audio from hard drive fast enough, hard drive may be fragmented, there huncke Pro Tools TDM Systems (Win) 6 02-23-2010 02:06 PM
Some Desktop Advice For A PC With One Hard Drive? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2007 01:04 AM
Partition Hard Drive? Clean out G$ hard drive? ike805 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2006 10:23 PM
Hard Disk Icon in the Desktop Alagu Pro Tools TDM Systems (Mac) 4 02-12-2001 07:09 PM
