Old 02-21-2003, 01:33 PM
eddybertrand eddybertrand is offline
Default I wonder if any of you know how to record a phone call
I'm working on a proyect that involves recording Phone calls, I wonder if any of you know how to record a phone call from my pro-toos 001? without using mics
Thanks in advance
Eddy
eddy
Old 02-21-2003, 01:45 PM
Lowfreq Lowfreq is offline
Default Re: I wonder if any of you know how to record a phone call
Check out Markertek (markertek.com) for phone devices (usually a box with phon in & out with a line in & out taps) that do what you need. Most broadcast supply houses have them in stock.
Old 02-21-2003, 01:46 PM
orage orage is offline
Rat Shack makes a cheap phone recorder. It was designed to be used with a tape recorder so the output of the device is on an 1/8" plug.
Paul Peterson
Sound Director
The Old Globe
San Diego, CA
Old 02-21-2003, 01:52 PM
ReniuR ReniuR is offline
The old answering machine I used to have (that used cassette tapes) was able to record phone calls.
-ReniuR
www.disposableproductions.com
Old 02-21-2003, 09:24 PM
Jean Chile Jean Chile is offline
I have a cordless phone with a mini (3/32") stereo jack that is used for I/O to a headset. I bought a mini adapter to 1/4" TRS and then split the signal in and out like that. It took some creative patching and phone work, but it worked great. I have a few phone lines here at my disposal so it was little easier and it only cost me $3 bucks. Definately NOT hi-fi but worked for my purpose. I looked into the markertek stuff but it was way too expensive for my purpose, I just lucked out and had a phone that worked already.
Producer/Engineer/Drummer/Golfer
I.B.S. Studios
The artist formerly known as Nine Spine.
Old 02-21-2003, 10:56 PM
JBRecording JBRecording is offline
Yeah, the headset jack on any cordless phone with headset capability works just like any regular insert jack...just get a 3/32" -> 1/4" adapter and you can use it with any digital audio system - not to mention, you can use a quality microphone to record one end of the phone call...
~John
MacBook Pro 15" Mid-2010
2.66 Ghz Core i7
8GB RAM
Mac OS X 10.7.3
Pro Tools 9.0.6
M-Audio Profire 2626
Kurzweil PC1x & M-Audio Keystation 61es
Old 02-22-2003, 08:59 AM
john1192 john1192 is offline
i suggest putting it into a DI for impedence matching...works great on my cell phone headset jack
peace john
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 02-22-2003, 09:17 AM
spoot spoot is offline
If you want to avoid rf and need a simple solution the JKaudio THAT couplers work great.
the THAT II has balanced inputs and outputs --> http://www.bswonline.com/prod_item.asp?item=THAT2
the THAT I only rca. -->> http://www.bswonline.com/prod_item.asp?item=THAT1
Old 02-22-2003, 03:22 PM
allstaar's Avatar
allstaar allstaar is offline
Last time i did this i bought a second hand telephone and connected a TS jack socket in parallel with earpiece ( this carries both sides of the conversation unlike the mouthpiece )
If i remember rightly i then fed this into the instrument input of an EMO d.i. box and passed that on to the mic amp on my console. I've got a feeling i could have padded the mic amp and gone straight in without the d.i. box.
I also set a mic up in the room with telephone which i found usefull in the final balance.
P.S. I think this may be technically against telecom regulations !!!!
Old 02-23-2003, 12:24 AM
RUNRUN RUNRUN is offline
eddy, don't know if this helps but it's the most effective way I have found to do it.
Unfortunately it requires a PC but I am suggesting looking for something like this for a Mac.
HotFax Message Center will record a phone call or conversation and save it as a wav file.
Just be sure to sset the max message length based on how long you need it to be.
It gives you a really clear phone type recording.
Recording Autotune via Phone Call (strange I know) bryced87 macOS 5 04-08-2013 01:23 PM
Do I really need to buy a $79.95 phone call to get an RMA? Lee Blaske Pro Tools TDM Systems (Mac) 47 10-28-2010 04:14 PM
is there any way to record messages off a cell phone? craiz730 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-14-2003 12:53 AM
OT: How to record a telephone call? staylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-30-2002 12:41 AM
How do you record a telephone call??? Camilo Orozco Tips & Tricks 14 04-15-2001 04:32 PM
