Volume in regards to mastering
I just have a quick question. I have been working on tunes for years and I have no problem getting the tune to sound great and only have one issue when it comes to mastering. How the hell do I get the the tune to be as loud as the pros? I have tried everything from multi band compression to a maximizer. So how do I get the volume to match up to other tunes?
Re: Volume in regards to mastering
make sure the master volume is not peaking 1st. as hard as it is turn down the volume so when you push it with the mastering plugins its not pushed already or clipping. 2nd mess with the eq so that the low end or high end arent driving it so hard that way it can be pushed louder. 3rd mess with an exciter then multiband comp or just reg comp then a stereo widener followed by the maximizer and limiter. there are many ways about going about it but I have gotten amazing results with izotope ozone 4 over t racks 3. its all personal pref. also outboard gear tends to be a lot louder than plugins for me anyways so yeah. one more thing give your track room to breath and remember there is a volume knob the customer can turn up to not be lazy.
AMD Phenom(tm) II X4 955 Processor 3.21GHz Gigabyte GA-790XTA-UD4 Total Memory : 4GB DIMM DDR3 Memory Bus Speed : 2x 670MHz (1.34GHz) western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:) western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (D:) Memorex DVD+-RAM 550L v1 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Windows 7 Ultimate 6.01.7600 x64 gateway 24inch hdmi dvi HD monitor pro tools LE 8.0.4 |
I have a very simple tip for do it yourself mastering, but first...
1) Selecting the proper instrument sounds are very important for perceived loudness. The kick and bass alone can make all the difference with a track sounding loud or better yet punchy. Most of the pro records you hear were recorded and mixed in top notch studios, with top notch gear, and everything was strategically selected for a huge final mix before mastering. 2) Speaking of punch, you're not confusing loud with punch, right? What may seem louder may just be the other track hitting harder or being punchier than yours. Limiting a track to hell will not make it sound louder but will in fact squash the life out of any punch and dynamics that is there. Punch is achieved in the recording and mixing stages. Mastering will simply enhance that. I say all this because I found it to be very true for me when I also found my tracks not sounding louder years ago. As far as mastering yourself goes the simple tip is, if you must master your work then invest in iZotope Ozone. If everything above is present, then the iZotope presets are great to start with and will make your great recording and mix a great master. You could always pay 75 bucks to a mastering studio like http://www.waltzmastering.com/ (who of course has dedicated mastering equipment). Not bad a price at all if you do everything else yourself.
in regards to advertising I must also recomend my friend john naclerio. his studios have outputted these following bands if you keep up with the times to get an understanding.
armor for sleep the ataris the audition autopilot off bayside brand new the dear hunter my chemical romance polar bear club etc. etc. he is doing a $30 dollar a song mastering deal and is good at it. http://nadarecording.blogspot.com/p/mastering.html
Thanks,,,, Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
Everything has it's learning curve. It''s just a matter of trying to utilize and get the best out of the tools that you have at your disposal. Check the un-mastered with the master at equal volume to make sure you are making sonic improvements and not just getting a track louder but worse for the wear. It's very hard to explain how to master and feel confident about the results on a daily basis. To me, it takes years and many many albums until you can feel you can really understand how to master on a level that rivals some of the best out there. (the original question) Quote:
http://recording.org/content/381-wal...mastering.html |
Tom I had no idea, & the fault of not checking, but ur rates are wonderful...
I'm @ som point gonna send a tune to u just to get a different perspective on it & maybe that 1 will turn into longterm work with u... believe it or not, I really do real work U guys on here jus think I'm a jokester & thatz the way~un-hunh-un-hunh, I like~ket
Thanks. I look forward to it.
I don't know Tom but came across his website (cool site BTW) on another forum and used it in my post. Quote:
yeah I believe they have an update for it on their site. avid has a link for it as well. not sure where you can search its on the forum. in either case I have been using it on w7 64bit no problems ever since the pt le 8.0.3 beta
Volume for Mastering. | KNM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 11-01-2010 04:34 PM |
Mastering/Maximum volume | sunnyside | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-03-2008 04:38 PM |
Mastering: Commercial Volume | nero120 | Tips & Tricks | 16 | 01-23-2007 09:51 AM |
Mastering volume | chaplain64 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-04-2005 06:33 AM |
How do you get the right volume when mastering? | DMP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-03-2002 07:50 AM |
