Expression pedal > Rig Volume > on To Amp out as well?
I have just bought an expression pedal and plan to use it to control my overall volume I'm sending to both the FOH desk and my monitor on stage. I've successfully calibrated it and set it to control Rig Volume. Works fine when I check what's happening on the Main Outs. But when I connect my personal monitor to the To Amp Out 1 (as I usually do) the pedal shows no effect. Can the Rig Volume control function be set to affect both the Main Outs as well as the To Amp Outs? Or is that limited to the Main Outs?
Re: Expression pedal > Rig Volume > on To Amp out as well?
Press and hold the edit/back button to get into User Options. Scroll down and go into "Volume Control". Select "All Outputs" . Press edit/back and go into "Persistent Volume" and enable that. Press the edit button twice to exit User Options and save your changes. That should enable your expression pedal to control all volume levels. There might be more to it but that has worked for me.
Self Built PC: Core i5 3570K @3.4 Ghz | Asus P8Z77-V LK 8 Gigs Corsair XMS 1600 | XFX HD4870 120GB OCZ Agility 3, 2 TB WD Green Windows 7 Home Premium 64bit Pro Tools 8.0.5 M-Audio Keyrig 49 Eleven Rack w/ERXP FCB1010 | Mackie SRM450v2 | Taylor 314ce | Ibanez RG321MH | ESP Horizon NT-II DSBS |
Thanks for the suggestion - but I've already tried / done that. The knob on the front panel works like it should (affects all outputs), but the exp pedal still works just on the Main out, not the "To Amp Out".
Bump...still having the same problem: Exp Pedal affects Rig Volume on main outs only, not on "to amp out". Anybody know a solution?
Hi Realmf,
I would use the Volume effect block to control your overall volume, by moving it to the end of the rig signal chain and setting the Pedal destination option to control it. Doing it this way will affect both the Amp Outs and the Main Outs. Also, the Volume FX has greater control over taper, so it can be better optimized for use with a pedal. And you can enable the "Persistent Volume" user option for Volume FX, so that volume level is preserved when you change patches. I hope that answers your question.
Chris Townsend Guitar Products Architect Digidesign, A Division of Avid, Inc. |
Thanks, Chris,
I don't know why I hadn't thought of that. It's so logical. Great tip, great piece of gear. Thanks again ;-) |
Xpand2, want the volume/expression pedal to be something else! | fredmant | Virtual Instruments | 2 | 01-13-2014 02:18 PM |
New User:help with expression pedal volume | gp81 | Eleven Rack | 7 | 09-23-2013 09:00 PM |
FV-500H Pedal works as expression but not as volume | World Spirit | Eleven Rack | 1 | 05-05-2012 05:35 PM |
Behringer FCB1010 expression pedal (for volume) | patswope | Eleven Rack | 4 | 04-08-2011 01:32 PM |
expression pedal for track volume: live | acroamatom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-06-2008 09:12 PM |
